frank
the whole kit i meant mate
Well, i will actually be able to put down the power now... my clutch is continually over heating.
Faster than my last turbo build? This is the same one man!
impressiveThat is the whole kit...
Right it says 10 odd, so 10-11Kgimpressive![]()
Ohh I see, no I will be seeing how far I can go with standard internals, but with a metal H/Gi saw these pictures of upgraded piston heads and clutch kit. i tho it will be faster than your last turbo build.
roughly stock weight thenRight it says 10 odd, so 10-11Kg
So that translates in to option a) lighten it b) leave it beroughly stock weight theni find throttle response/spool-up is very critical on a turbo build personally chris
Lol this wouldnt do any good ona strip.We having an MSC day at the RWYB at Santa Pod when this beast is alive then Chris?
yeah i know, but its embarrassing there will be shed loads there which will hand my arse to me on a silver platter.Turbo'd K11? You kidding? Harlen did it with his N/A 1.0L - <Miranda's mums voice>such fun!</Miranda's mums voice>
wouldnt they put me up agains big boy cars... i dont want to play with big boy carsTurbo'd K11? You kidding? Harlen did it with his N/A 1.0L - <Miranda's mums voice>such fun!</Miranda's mums voice>
wouldnt they put me up agains big boy cars... i dont want to play with big boy cars![]()
oh thats not as scary then.. thats okay then. will have to have a go.RWYB is just a free for all, you'll just be next to whoever you're next to in the queue and you'll be surprised what you can stuff in a turbo k11.
I'm game for that too!oh thats not as scary then.. thats okay then. will have to have a go.
What's this msc day thing I don't know eitherI'm game for that too!
Did plan to take mine to the first rwyb if the year, but I broke it
When's the msc day thing happening?
Is there an arranged event then guy?We having an MSC day at the RWYB at Santa Pod when this beast is alive then Chris?
If not......make one,Is there an arranged event then guy?
Throw some Radials on the front, you'll be fineyeah i know, but its embarrassing there will be shed loads there which will hand my arse to me on a silver platter.
Ta man.luvely pics
my 200mm full-face organic helix clutch handles the 160ftlb 160bhp on track no prob at all nowadays, and that's only using 50% of the surface cos my flywheel was machined concave.
so 150ftlb should be a pieceapizz.
the ceramic paddles are a very hard tough material so will hardly wear but it will indeed chew through the softer steel flywheel/PP especially when it's abused on a drag strip or track
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-50#post-509270
suppose the paddle arrangement promotes a harder high-pressure bite but during traffic jams it tends to shudder/chatter during slippage.
I used to have a thin ultra-light JUN flywheel and although it reduced the time for the rpm to blip during heel toe and for the rpm to drop fast during up shifts, it had a very limited heat-soak, heat-sink capacity. so coupled with a small-area paddle clutch it was more likely to overheat quickly and glaze permanently under intense stress.
with the 8kg stock flywheel here I just get used to waiting for the fly to gradually slow down during upshifting.
LololololI had a hot hatch once...
...after too much chilli.
This trueI imagine your walls are like a custard cream...without the filling![]()
I can't do anything till after uniIf not......make one,![]()
I have been informed that paddle clutches are bodges .
Yes I do agree. Even with my three piece I noticed the suitability to certain scenarios.I'd say they are suited to a certain purpose. When things go wrong or do not meet expectations it's either down to a lack of information/understanding and/or misuse. For racing conditions where you only make one or two starts, (off the line and pit stops), they're great. For start/stop traffic situations and general driving, they are less suitable.
I am sure the driving style of the other chap is why that clutch didn't measure up to expectations and was swapped out for an alternative.
Me personally, I will send my 68-110R off to Helix to be re-sprung to a 68-110G, so I can use a full face organic plate instead. It will handle the same torque but be much more suited to street conditions and treat the flywheel and clutch cover plate better.
As Paul said, light flywheels pose the disadvantage of a reduced thermal capacity, which can be a major downside when using a paddle clutch, especially on the street. Everyone is different, but I find in general a slightly heavier flywheel offers more advantages than disadvantages on a street driven motor, (within sensible limitations).
Bottom line, you have a very nice setup there that wont let you down and will ensure 100% to the road at all times. Pedal effort is increased but, from experience, it's perfectly manageable![]()
Well I never knew! NSS only counts if you are well versed. Not fairOne of those NSS statements but a paddle clutch will wear the flywheel more than an organic plate. The effect on wear increases as the number of paddles is decreased.
Unless you're planning on exceeding 215lb/ft, the 68-110R cover you have will more than suffice with an organic plate. 68-110G not required.
If you're not bothered about drivability, try what you've got and see how it is. Junctions are fun though and it'll be plenty more snatchy than stock![]()
eeerrm dude what you done to that battleship?
Everything I want to loldude what you done to that bumper?
