30kg?Not 30+kg of turbo stuffs though
You're on 300lb fronts?I has 30+kg more engine, I don't think his turbo stuff weighs close to that, testes or not.
Eagerly awaiting feedbackWill be when they arrive
Massive amounts30kg?
How much does that turbo weigh
have you ever had the issue of instable revs at high end... I really struggle to keep the revs high and the car going at a stable speed... the motor like jolts back and forward...What dya mean no fun?
Last time we spoke on hear you told me your balls weighed 30+kg
Sounds like you do with a new throttle cable and some stiffer mounts
Could be the plugs giving up, are they colder plugs than stock?have you ever had the issue of instable revs at high end... I really struggle to keep the revs high and the car going at a stable speed... the motor like jolts back and forward...
Only because I had a fueling issue with my carbs at full whack. But yours has been mapped to suit? :/have you ever had the issue of instable revs at high end... I really struggle to keep the revs high and the car going at a stable speed... the motor like jolts back and forward...
its ever since you know when lol bloody ferritsOnly because I had a fueling issue with my carbs at full whack. But yours has been mapped to suit? :/
You checked your mounts at all? :/its ever since you know when lol
The rubbers see if they've torn etc?they are still attached lol? or the rubbers?
Just checked... OpppppsssssThe rubbers see if they've torn etc?
I'll try get some ptfe mounts made tomorrow if you like?Just checked... Opppppsssss
Might be a small tear to us but 150hp might say differently.Nor terribly. But if I can see a tear. There could be bigger issues at hand. Could that cause rocking of engine... Jolty car
I got the rubber ones here I think (at least the drivers side anyhow)Omg....pleaseeeee you know the size for sides and rear son?
nice rug broView attachment 30013
Will have a go at it tomorrow if I get the chance. I'm assuming the steel inners sit central when the engine weight is on them?
You don't love meSide mounts to begin with. Like I said, if i get time. Theres a state of the business address for an hour, and I have some zeiss inspection binoculars in pieces that needs reassembling... I'm sure I can blag lathe time though.
Oh i didn't notice haha, felt smooth enough to mealloy ones andy ?? you drove it the other week you tart![]()
