What didn't make sense :/That made no Feking sense. Yeah. Chuffed I used my noggin on that one.
Pretty sure they are?a pumps flow rate/pressure are not directly linked with RPM
As early as you likeWell I had a quick 5 mins and I put the restrictor on got the car warm.. Ragged it when oil got warm.. Et voila no burning oil. Still tomorrow I will flow test it with and without restrictor to be sure. Things are looking good. Well either way. The lack of burning oil will help with mot. Hoping that the standard fuel pump and sr20 cat we can get it through the mot. Andy when you hear tomorrow?
Sounds clever mate.As early as you likeprobably 9 ish
Go on son!
Sent from my HTC One S using Tapatalk 4 Beta
But I may be starving the turbo. So we need to do some workings out eySounds good Chris![]()
They certainly are mateyGotcha guys, in my head it was a centrifugal pump for some reason, is it what they would call a positive displacement pump?
welcome to 15 year old rear disc brake mechanisms chrisSo rear handbrakes are not working. The brakes yes... Hand brake no... Ffs.
Drum brakes ftmfw!welcome to 15 year old rear disc brake mechanisms chris![]()
Shh uwelcome to 15 year old rear disc brake mechanisms chris![]()
Lol all the coppers I spoke to were all right.Need to get that tread coveredor Mr Rozzer won't be impressed
Will go through all of this tomorrow mate I think. Enough for tonight .. actually stuff it will have them off tonight and have a ganders. They move out and in just very slightly.looks pretty badaas there without bumpers
- loosen the cable end nut,
- knock off the handbrake cable clip from the caliper support arm,
- take out the rear caliper,
- unhook the cable end from the caliper handbrake arm,
- while someone moves the handbrake up/down and you keep the inner cable taught at the other end, check if the inner cable slides in/out smoothly,
- grab the caliper handbrake arm with pliers,
- turn the arm fully on/off making sure it turns smoothly and springs back fully to its resting point without sticking (sticky/resistive = dried grease inside or seized arm or seized mechanism),
- visually check the piston nudges in/out slightly as the arm is turned (no movement = handbrake engaging central shaft in the caliper is seized).
Yeah the top of the tread. Tread is what is in contact with the ground. And I am not bolting on arches like u haha. Not ur fan boy yet hahaReally? Was under the impression all tread needed to be under the arch. Small 30mm bolt on ones will look smart
Weirdly yeah lol^ that's almost a before and after![]()
I am going to work with the mot bloke to get away without bumpers.looks pretty badaas there without bumpers
Yeah I still swear she burning oil. Dunno what to do. The car stinks. It may be oil/paint and other brake and steering fluids burning out the engine bay and what not. Really worried about this mot. Dunno what to do. hoping she will be calm enough on the up the bum exam. ahhhhh the panic! V5 hasn't turned up so I cannot bloody tax it. Gahhhrrrr fix it jen.....she's almost there now huh?...shame the Turbo's giving you jip <_<
Ta mate we getting there. mot WednesdayLooking good Chris
Really Andy...really.Tighten cable?
Sooooo....It's not a continuous flow pump (such as a centrifugal pump) so actually flow rate IS proportional to rpm. Maximum pressure however is dependant on the effective swept volume of the pump I believe.
Take a pic of our results and send me, will do a writeup on this thread mateSooooo....
I miss the obvious that often I thought I'd throw it out thereReally Andy...really.
