Its works that's the main thing
Ooh. Getting feisty are we
More like panicking with 4 1/2 weeks to go with a fresh engine
Need bed in time
The more the better with gradual increases in harshness etcWould you recon 500 miles would be enough?
Aren't you meant to use a 'bed in' oil, that has zinc, or is it magnesium , soft #### added to it to help break stuff in?
I think that's mainly for breaking in new cams/flat tappets on big blocks.
I just use cheap mineral frequently for the first few hundred and till its fully bedded n sealed then use any type afterwards.
Barely. It depends on the bore finish & bedding procedure, my forged pistons took at least 1.5k till it stopped smoking and 7k till the pistons weren't pooling oil.
Paul, (Pollyp), your bedding in isn't really representative of what an engine 'should' take to bed in though sadly
A decent diamond honed block with new rings will seat in very quickly. 500miles should be plenty to ensure good bed in on a fresh engine before swapping over to a semi-synth/fully-synth.
We all have our favorites , I use Millers CRO.
Soon be play time
Freshly built alarm clock and all thatIf it's not running this time next week il be very disappointed!
Got to wake the neighbours up some how!
I was jus trying to look smart after watching blokes on that fast and loud program break in their engines
Your right, they were big block v8's too
man, did they had some bad luck with their bedding in...
lol I want to know what happened nowI was jus trying to look smart after watching blokes on that fast and loud program break in their engines
would you be able to shorten that time on an track for example? continual speed change and rev monitoring? How would a motorsports team do it? I have seen this guy who breaks in bikes by opening the throttle up with control in rev at increments. The pushing power expands the rings causing the friction more effectively. Is this stuff a dark art or just lots of people cocking it up? Surely if you get it done right when the bores are done the seal should be near perfect? Also could you not just run in an engine with just a weekend trip to like nottingham and back in one go? haha ALL the questions. Could skinner just continually drive around the island for a day or two?Paul, (Pollyp), your bedding in isn't really representative of what an engine 'should' take to bed in though sadly
ha! I still love the offerings to god of speed wall! I shall be doing that in my workshopLike the opening sequence of that Anthony Hopkins film "The world's fastest Indian" starting his shed built land speed motorcycle in early morning
We warm it up at 2,000-2,500 rpm for 10 or so minutes so its thoroughly warmed through. Then load it on a dyno so we can monitor it.would you be able to shorten that time on an track for example? continual speed change and rev monitoring? How would a motorsports team do it?
Yeah theres no right way, but there obviously is methods which do work better than others... if nissan made me a micra engine which lasted 280 thou, then they must of bedded in the engine somehow? Correctly...We warm it up at 2,000-2,500 rpm for 10 or so minutes so its thoroughly warmed through. Then load it on a dyno so we can monitor it.
If the map aint right... breaking an engine in on a bad or insufficient tune aint good. But they're race engines. They're built to scream hours on end
Theres no right way to break an engine in I reckon a day or two of steady driving should be fine. Checking plugs for air/fuel mix the old fashioned way
@pollyp did you compression test your bedding process at various intervals, seems like something you would do. results?
But then on the other side I see why people don't give it such effort. The main reason being if your engine is honed properly and rings properly gapped etc then they're already gonna be near on perfect.@Skinner_87 I figured you might be interested in this sort of chat, please tell me to shut up otherwise.
@h701micra so once again the internet ssays stuff.. people dont really know then?
Not exactly the gentle break in you'd expectthe best fix to my leaky oil ring was after I pushed her on a trackday in Feb and she sealed alot better.
Whatever happens. I will give my engine, pistons, metal H/G and rings to someone who knows what they are doing. I may just give someone the car so they can bed it in too... if it dont seal its not my issue then. * plus I dont want to have to spend countless amounts of money fixing my mistakes.
@Skinner_87 what has your engine makers said? ** engine builders, god i speak like a muppet
Good warm up and a good run and I'd say you'd be set to goThe machine work was done by Matt's engineer so i've 100% faith there.
My engine builders my dad, time served at Datsun/BMW & i've never seen any problems with anything he's built up
sorry mate i wasnt implying urs aint going to work. I was wondering what has been suggested to you?The machine work was done by Matt's engineer so i've 100% faith there.
We all have our own methods. I change oil & filter within the first 50miles, then again at 500mile intervals before switching over to a synthetic oil.
Regardless of break-in methodology, that first oil change is the most important one as it's likely to be full of the most deposits you'll want to get rid of.
Now turbo or gtfo
Good work Dyno print out time and full spec.
145!! mad, need a full spec sheet for sure , good job paul!!
@h701micra mentioned something about the gearbox I have being rather sought after for racing/sprints ect?
