This looks almost exacly like the photoshop i've done of my planned track K11. Damn you! Now i have to change my plans..
Still need to get them shortened shocks fitted, hopefully that'll give it a lower look...
only the springs make the ride hight diffrent (all the weight sits on the springs) shocks dont have anything to do with ride height. so they shouldnt make a diffrance.
(Y)
When I was parked next to modded at ISTS, his looked lower than mine. And he had the same lowering springs, with shortened shocks, mine were standard shocks. Ill see when they are all fitted. Done the rears today, soooo much firmer than it used to be!
Yet again, cheers for all the feedback peeps! Its much appreciated!
if the distance between where the shock attaches to the hub and the spring seat is different, then the spring will be sit lower, so the car will be lower, plus the shock will be designed to work with shorter springs so should be more effective
The wheels are these: (believe i have the 8j and 9j rims)
http://www.dubmeister.co.uk/wheelinfo.php?make=Steffan&style=BCW 5 spoke
I got them second hand from a guy for £350 on ebay. Had to get new tyres all round, was a pain to find some for the rear, at they are 14" rims! Managed to get all toyo's!
