NISSAN Micra Radio Code Please!
After going to junkyard and getting another one, I learned the code is also edged on the side.
BP334958140719
The replacement radio has:
BP234732024745
7 642 347 318
Can you help get a code for either of these?
Thanks you very much!
Anyone able to help me got the k14 model of the micra just swapped headunits and its come up with secure system locked red please contact dealer can someone help me on this issue
Hello! My micra is second hand and after the battery went flat I realised I was never given a code.
Serial number 3137874
Device number 7612830023
Date 10.04.28
Any help gratefully received!
HI,
same for me. Car just got new clutch and now requesting code. Card dealership game me is not working and cannot get back til Monday...
Serial number: DW49N21971
Part no 28185 3HN4B Prod date
14-10-03
Thanks in advance.
Hi, the battery on my second hand 05 Nissan Micra had to be replaced and I wasn't given the code for the radio, could anyone help please? Serial number is BP334958128492 and the other number is 86351233920. Thank you
Hi all,
This thread had gone a bit quiet so resorted to a paid solution.
This company was best out of all the research I did. £4.99 and code instantly provided. Just needed the BP number and 10 digit serial number.
Thought I'd share incase anyone else finds it useful.
Hiya, my dad and I recently changed the fuses in my micra and now don’t know the radio code. Was wondering if anyone would be able to help me out? TIA
Serial Number: 3144447
Decide Number: 7612830023
Date: 10.07.01
Hi all,
Cheers for reminding me about these guys, as a mechanic I've used them a few times now, each time they delivered the code instantly to my email for a fiver, and just now I didn't even have to include the 10 digit part number
They can't do some of the other Nissan serial numbers in this thread but if you have Blaupunkt/BP serial numbers these are the guys to go with. This is their Nissan page that I use: https://www.rapidradiocodes.co.uk/manufacturers/nissan
Hi. The only numbers I could find on my Micra 2006 radio are:
55610021061 (label at front of radio)
8 635 123 390 0 (number from back of the radio)
Someone wrote 1695 with a marker on this radio, I was happy I found the code but its not working:(
Can someone help please?
Hello I don,t suppose someone can help me with a radio code please. Recently inherited a Nissan Micra with a flat battery that had belonged to my father.
Serial Number: 2380027
Device Number: 7612830051
Date: 11.02.01
Thank you In advance.
Hey, maybe someone can help me, just bought my micra and the previous owner doesn’t remember the radio code, and I can’t find it anywhere
The Serial number is: HY68N04483
Part number: 28185 3HN4C
Prod Date: 16.08.17
Prod Date: 16.08.17
Hi,
Could someone please help with my radio code?
I’ve just bought a micra 14 plate and don’t have the radio code.
VIN: MDHFBUK1300759812
Thanks will give it a try issue is its stuck on wait 1 hour for a few days. And out of the 2 codes if 1. Is wrong how much longer will the timer become on the radio safe lock
The 'wait one hour' message goes away after an hour WITH the radio turned on and the ignition on, so go for a drive and it should reset...
Hi John. I don't suppose you'd be able to suggest one for my newly-acquired '14 micra, please? It's DW3BN04251. Thanks in advance.
Hi hope you can help me get code for radio cassette, the only numbers I can see on my 2005 micra radio are BP-7-a-va 2892-0038989-12 & BA 02 8001 or 59700020885 not sure which one to use ☹️
