The original's were intended for a shock absorber, so no direct load (taken throught the spring)Are the rear suspension components actually coilover? Because the majority are spring and damper units (separate parts). Excuse me if that is a stupid question, the amount of people that don't understand the difference is quite high...
The fronts will obviously be coilover, if the rear are to in not sure what you'd do? @h701micra might have a clue or two
someone has a scheme/guide about weldings and chassis reinforcements?The original's were intended for a shock absorber, so no direct load (taken throught the spring)
If it was me I'd have the turrets strengthened to take the load.
Easiest way is a 2/3mm plate welded in the arch, NOT on top inside, to spread the load
Sorry I was late to the party![]()
rob posted a pic of his nova onesomeone has a scheme/guide about weldings and chassis reinforcements?
The top cup was the one that was supplied with the coilovers, it's the top mounts that are causing me hassle. I tried ringing Apex and they won't sell just the top mounts separately the pic with the blue cup thing is now gone and I'm using 2x top mounts on each side one acting as a spacer for the cup and the other as the actual mount. The issue being that on the shock itself the thread isn't long enough to use either top mount on its own with the two locating spacers. The way I have it now seems to working fine it's a shame you can't order BC Fronts and Gaz rear shocks I haven't noticed anything wrong with the rears at all though. And I just read what you mean about the rear the rear shock mounts are just to absorb impact and not take weight whereas the spring perch on the axle takes the weight. I'll have an ask around later this week as I need some body work done anyway@LondonTownie I'd be very skeptical on the safety side of the top cup design you have going on there, alot of potential for slip and failure, other than that, good work![]()
and reinforce weldings on the rest of the chassis? which is the weakest part of a micra body?rob posted a pic of his nova one
http://www.micra.org.uk/threads/anyone-fitted-corsa-b-rear-coilovers.52511/
to make that area stronger, and to make room for the springand reinforce weldings on the rest of the chassis? which is the weakest part of a micra body?
A nice shiny alloy top cupwould solve the issue, not a sales plug genuine solution.
Holds the springs as it should and will work with the top mounts properlythey're active all the time not just cornering
Thanks, although the top mounts are a bit of a mix and matchNice set up LondonTownie.
When you say make room for the spring, there seems to be plenty of space for I can fit three fingers between the spring and the body and there is the same amount between the wheels tooto make that area stronger, and to make room for the spring![]()
The part about not a sales plug was because I already make such thingsIf you can come up with a solution H701 i'll be more than happy to purchase some off of you![]()
rob did it to make room for the true coil-over type by the looks , not the coil-aside onesWhen you say make room for the spring, there seems to be plenty of space for I can fit three fingers between the spring and the body and there is the same amount between the wheels too
