they fit nice and snug into the stock rubbers mateCheers, can I use the standard black rubbers on the cg13 mani still? Or would I need the others?
Surprisingly yesEngine back in.......again, should time myself, do it so quick now lol
That BMW mini bypass valve is next to the throttle body, and once pipe arrives, the air will be recirculated back into turbo inlet, and with the new air tight changeover valve, should be quite a bit more pressure on idle, was 2 psi with old valve with the mini bypass open to atmosphere. Will have to wait and see, see if it causes a problem
Mocked up boost pipes too, looks a bit mental
Oops, surprisingly yesDoes the bumper fit over all that? Lol
any thoughts on the kdfi ecu neil ? built in map eh http://www.redline-developments.com/index_files/pcb.htmCheers, looks like end if this month now before I buy ecu. But ok have everything else ready, litteraly nothing else to do apart from wiring
dunno tbh mate, an MS clone i guessNever heard of it mate.
What you think of them?
Sounds alot like tge nodiz setup I boughtDoes the cga coil plugs got all the engines?
Been talking to people at redline, and they can run wasted spark from their ecu without the cord edis
yes they slip on neil, there,s no thread for the retaining bolt in the cam cover, but they are not gonna go very farYeah
Aaahh, that's ignition onlyGot this one
www.motorsport-electronics.co.uk/index.php/nodiz-pro-ignition-only-ecu.html
Comes with the ecu, loom, consult dongle thing. So not much really
Ah yea... no good for you then :/Aaahh, that's ignition only
I may have some coils If you want neil?Not anymore![]()
Just relaying the messageThere's no real advantage to wasted spark. The name says it all, its a spark that is wasted and has no purpose other than pub talk.
of courseYou got one gong spare for sale?
that is the oddball 4 slots and a hole signal tho andy, i think the MS options only cater for 36 - 1 or 60 -2 or 360 pulse signalsOr you could try using the CG dizzy optical sensor![]()
