I do, kindly donated from ade
thats a glitch on the phone app on here i guess neilDon't know why it's brought up a pic off Jamie's alternator whilst quoting frank?
Its a reminder to wire in your alternator![]()
Sent from my HTC One S using Tapatalk 4 Beta
One at a time? Closest to master cylinder and work your way away from it![]()
it's going
Not for long as I've ran out off petrol
I think the poor thing needs putting out of its miseryCan anything be done to help the clutch out?
definitely helped mine, but your 160mm clutch has no hope past 100hp mateDam!
Does that spring help, spose it makes the pedal quite heavy too
Seconded!Fair play Neil
This will be a real weapon once the drive issues are sorted
Pm me your address Neil I've got one you can have
Whoah!you have to swap the cushdrive/middle over neil, easy peasy(drill 4 rivets, and replace with m6 bolts)
Just want to add my well dones Neilapart from the niggly bits how was it?
thats a 160 and 200mm one tbh mate, but yes.Whoah!
So that's the middle bits from the bigger clutch, bolted to the smaller?
your cover is 170mm, so you have to bevel the edge of the friction plate, so you end up with 180mm against the f/w, and 170mm against the pressure plate, and an RS5F41 spline in the middle
which will hold 140hp +![]()
