,line bored neil inlet 123 etc exh123 etc, arrows pointing at the chainGunna start on engine this week, jus been going thru bits n bobs, and realised there's numbers on the cam holders, is there a certain plane for each of them? Or can I bolt anything anywhere?
Yes I know I should of made a note of what went where
there,ll be some bobweight springs underneath neil (centrifugal thingy)
does the vac mech push and pull neil ? if it extends when you blow into the diaphram then you will get boost retard eh.So shall I rip out vac stuff, take out weights and weld it in place with it fully advanced?
Haha, sureNot really thought about that bit.... a few fittings
you can leave the plate off if you like pork, frank and I have run without one for years. more cooling for the clutch eh
I'd say soDoesn't dirt and #### get in?
nah, mine,s got extra ventilation too neilDoesn't dirt and #### get in?
The clutch is national, yellow box, blue triangle with national across it
