pollyp
my job workload is just non-stop long hours and god knows when I'll have time to work on the car.
for now lets measure the condition of the stock engine
measured the bores and the upper sections abit oval but the average bore diameters from 71.02 - 71.07mm
the max standard bore dia is 71.03mm so this block has had it
measuring the piston ring end gaps are no better. inserted the oil rings and look at that 1-2mm gap!
end gaps measure (top, 2nd, oil1, oil2)
cyl1: 0.457 , n/a , n/a , n/a
cyl2: 0.432 , n/a , n/a , n/a
cyl3: 0.457 , n/a , n/a , n/a
cyl4: 0.457 , n/a , n/a , n/a
all of the gaps are beyond the 0.635mm my feeler gauges can read :/
the piston skirt dia and piston-to-bore gap are
cyl1: 70.93 , 0.104mm
cyl2: 70.91 , 0.125mm
cyl3: 70.93 , 0.108mm
cyl4: 70.91 , 0.124mm
the max piston-to-bore gap is 0.03mm!
also measured the oil ring tension drag with abit of wd40:
cyl1: 3.5kg
cyl2: 4.25kg
cyl3: 3.5kg
cyl4: 4.0kg
well I believe I can conclude that this stock engine is utterly worn and not worth building
so it's all down to this new rebuilt forged engine and I've got no spare engines.
cyl1: 3.5kg
cyl2: 4.25kg
cyl3: 3.5kg
cyl4: 4.0kg
