lets rebalance the car with the bad tyres.
disconnected the swaybars
levelled the scales, much easier n faster with the new leveller frame.
1/2 fuel tank, washer bottle full, dumbell ballast on and tyre treads are
FR 6.75
RR 4.0
RL 2.5
FL 4.5mm
the loading and ride heights are
FR 283.9kg 102mm
RR 171.9kg 100mm
RL 179.3kg 100mm
FL 297.4kg 99mm
the FL/RR crossweight is highest.
either reduce the FL preload but ride height was already low,
remove the FL ballast but cba,
increase FR ballast but no room and cba
lets try swapping the thinner rear tyre to the RH
FR 285kg 100mm
RR 173.2kg 100mm
RL 177.2kg 98mm
FL 298kg 100mm
meh that'll do cos cba to move ballast or adjust the coils
wheels still straight
well I've decided that if it's raining at the track, I won't bother with attempting to balance/align the setup cos it will NOT be enjoyable to tinker in the soaking wet with no cover.
also it's taken me 2.5hrs to just balance and align the car, erm thats half the track morning and afternoon wasted setting up the rig, tweaking and reassembling the car rather than driving :/
the rear parcel shelf appears to have sagged over the yrs from the heavy speakers and began to rub/rattle against the boot annoyingly. thought of sticking rubber pads but won't work
here's the banana'd shelf against a straight bar
so I drilled a pair of holes
and screwed a square tube underneath to straighten n support it
clear
but in tradition of things going wrong before any important events, I noticed an unusual green pool of coolant on the floor?
the fins and hoses don't have any damage or leaks but the bottom end of the rad is wet with green coolant, huh where's it coming from?
coolant tank was running empty, took the rad cap off and its empty.
grabbed a bottle and it took almost 1L to fill it up! eh so tonight I might've been driven home with almost no coolant!? surprised it hasn't overheated.
after filling up, checked around and OMG I see it slowly trickling out from the lower section of the rad!
Ohh FFS what the H
there's no visible damage, could be cracked?
cos the trackday is on sunday, I'm gonna have to urgently order another k11 auto radiator aren't I?
