:O £30 jammy git, is it gas?
excellent ed (Y) is the map more suited than a maf on your setup ?
Sensor will be fine. Thats a strange timing wheel just one tooth per rev?
BTW I prefer MAP on turbo cars. You have to have a AIT sensor too but they are generally better once setup right.
Ed
14.8 means your sensor is cold usually.
Still two teeth is really uncommon, Can the ecu not use something like 36-1? May be too late but the system would be much more precise then.
Hope you get all sorted, would be nice to see it running strong![]()
The old owner of that ECU cant send you the ROM he used? BTW check your inbox... lol
By ROM do you mean the settings he used? I dunno, iv had no luck contacting him. but btw that screen shot is not with the ecu connected, its just what you get when you load the softwear (hense all the 0's).
I checked my PM but there isnt one from you? was it full? iv deleted some now(Y)
Edit, Replied baguete(Y)
Yeah, but im not sure that the setting were all that good tbh, it was supposed to be setup for that MAP sensor but it was reading 40% load at idle:S I did save the ignition and fuel maps (turbo) that it came with though so that might give me a helping hand when i bolt that blower on(Y)Yes, the settings he used on his car, maybe you could use them and then tune it to fit your mods...
Replied back![]()
Yeah, gave him a quick bell today! top lad!! thanks for that mate! That Nistune sound pretty good!have you been in touch with phil yet Ed?
Type 4 board. Im ordering some more soon if you want one.
good(Y) think there is somthing wrong with the controler atm as its reading 14.8 all the time (think its a common prob with the TE controlers by the look of their forum:S) hopefully it will just need recalibrating.
Its two teeth per rev mate, the one on the bottom is a bit hidden in the pic maybe?
The constant 14.8 reading turned out to be a dodgy cable so TechEdge are sending me a new one![]()
vaccume mannifold???? show meeee
i got the brace sorted to it looks the muts! i think im going to make the same one for the front too. there big and bulkey and look the biz
nice one Ed, looks a bit to messy for me.....i like things nice a neat
im still having trouble getting pics on my laptop f'n windows 7 but as soon as i sort it i'll send you the pics of the injectors and the brace
Cheers mate, I wouldnt call it pro though, its not going to be blingin engine bay, it will work though. the pipe is just IC piping i picked up in a breakers yard including some i got from a cop carlooking very professional ed (Y)
