Its been a while.
Yesterday I did a little messing around.
Checked for fault codes and found 'crank angle sensor' was playing up. took the dizzy apart and put it back together and the fault has cleared.
So a while ago frank was talking to me about using a second coolant temp sensor placed in the cabin to fool the ecu into running richer because it thinks the engine is cold.
I wouldnt say this is an alternative to mapping!! but it did make my car absolutely FLY! It does however make it nearly undrivable at low revs due to rich misfire. Doing it has showed me how much potential my car has when properly fuelled. VERY chuffed with it!
The car is still filthy and smelly.
give us more info on this crank angle sensor
i was thinking their face lift only?
