Hi, either3661 or 1661 should work.....Good Morning,
Can anyone help me with the radio code for my daughters Micra?
SN: BP538461723112
Many thanks
Hi John would it be possible to get mine?Hi, either3661 or 1661 should work.....
Thank you JohnHi, either3661 or 1661 should work.....
Hi mate can you please help me mine code isTry 5202 or 1202.....
Hi, try 5179 or 1179.....Hi mate can you please help me mine code is
BP538461723092
Thanks again
Hi, try 9954 or 1954......Hiya there, new to the forum. Could someone help with serial no. BP538469473107
Hi can someone help me with a codeHi, try 9954 or 1954......
And me please, Can anyone help please, nissan micro radio code lost , 7643349318, BP334958112749Would you be able to help me too please? My serial number is: BP3349 3 6378088
My daughter had same issue and says wait 1 hour to try another code. We tried 1111Try 5202 or 1202.....
My daughter had same issue and says wait 1 hour to try another code. We tried 1111And me please, Can anyone help please, nissan micro radio code lost , 7643349318, BP334958112749
Thanks I'll give them a tryMy daughter had same issue and says wait 1 hour to try another code. We tried 1111
The serial number is BP234732035188 can anyone help with a code? Thanks in advance
Don't use anyone else's code, they are specific to the radio serial number and you may end up locking the radio.....My daughter had same issue and says wait 1 hour to try another code. We tried 1111
Thanks I'll try that in an hour ?Don't use anyone else's code, they are specific to the radio serial number and you may end up locking the radio.....
The code that you need for your radio is 0850.....
Superb thanks so much it worked ??Thanks I'll try that in an hour ?
Hi, 3534 or 1534 should work for your radio....And me please, Can anyone help please, nissan micro radio code lost , 7643349318, BP334958112749
Hi John, works perfectly, thanks for your helpHi, 3534 or 1534 should work for your radio....
Hi JohnHi, 3534 or 1534 should work for your radio....
Hi, 1057 is the code for your radio......Any help with Nissan micra radio code? Serial no is BP334947254435 please
Well, the thread is still active, but I do have doubts about myself sometimesHiya not sure if this thread is still active but please could you tell me my code?
BP538469508628
Thank you![]()
Thank you it worked!!!Well, the thread is still active, but I do have doubts about myself sometimes. The code that you need is 1104
Hi, looks like 0318 will solve your problem....Hi John,
My radio serial number is: BP738387800707
Thanks!
You are in luck Jim, 8285 or 0285 should solve your problem.....Hello. Hope this thread is still active.
Could someone kindly please give me a code for my stereo? Had a battery change and it's now gone. Thank you
BP234631989198.
Jim
You sir are a legend.. now I don't have to listen to the rattles anymore. ThankyouYou are in luck Jim, 8285 or 0285 should solve your problem.....![]()
Model AGC-3220YF-BHi can I please have a code for 281853HN4B
Please #John_DModel AGC-3220YF-B
Date 10.12.2013
3344 or 1344 should solve your problem.....Hi John D..
My serial number is - BP538471192416
Can you please try and get my radio code for my grandmothers beloved Micea.
as I changed her Battery last week ..and she is doing my swede in about no music when she drives.....cheers.
