Hi John, could you help with mine too please? The serial number is BP538471191528.Try 5202 or 1202.....
Thanks!
Hello,Hello,
My S/N is BP234732031985
Can you please check pin for my radio?
Thanks very much in advance!
Cheers,
Raf
Hello,Hi John, could you help with mine too please? The serial number is BP538471191528.
Thanks!
You already have the correct code, I can confirm it is '2072'. Turn the radio on and go for a drive, the 'wait for one hour' message will go away eventually and be replaced by either'CODE' or '----'My nissan micra sve pass code is bp2347 serial mumber is 32022271 safety number is 2072 but stuck on wait 1 hr please help what is the right code
Thank you very much!Hi,
Code is . . 0971
You have to remove your CD player unit and it's on the back.Where can I find the serial number?
Hi all! I have a 2006 convertible Micra. After some work at the garage, the CD player requires a code that I don't have. Can anyone help me? The serial number on the back of the unit is: LP 8 635 123 615 3
Thank you.
Post any labels stuck around the radioYou have to remove your CD player unit and it's on the back.
Thanks!
There's a label that says K126004669. Thanks.Post any labels stuck around the radio
Try . . 8682Gents,
May I have the radio code for the following radio:
BP536555904441
7645365318
Thanks in advance!
Jasper
Worked perfectly, thanks so much, hero!Try . . 8682
Can anybody help with mine, please? The number above is on a sticker on the CD player unit, and this is the serial number: LP 8 635 123 615 3.There's a label that says K126004669. Thanks.
try . . 9210After changing battery locked out of my Blaupiunkt/Nissan radio in my Micra C+C 2006. Serial Number is BP538764214334. If someone could help me out with the Code that would be much appreciated. Thanks, Theo.
See link => https://www.micra.org.uk/threads/k12-radio-codes.37292/post-717897Can anybody help with mine, please? The number above is on a sticker on the CD player unit, and this is the serial number: LP 8 635 123 615 3.
Thanks so much!
Hi Roan, can you clarify what I should be looking for on that link, please? I'm confused. Thanks.
Hi NellWHi Roan, can you clarify what I should be looking for on that link, please? I'm confused. Thanks.
Works great. Thanks for your help.try . . 9210
Ukraine Crisis Appeal
Help provide material support for people affected by this conflict in Ukraine, by donating today. Our staff and volunteers are working working around the clock.donate.redcross.org.uk
I have Nissan micro same problem bp334947254455You have to remove the radio from the dashboard to find the BP number on it, either on a label or more often engraved on the side and/or back of the unit.... A Nissan dealer can give you the unlock code for the radio, using the cars VIN number (assuming the radio is the same one it left the factory with) BUT they will charge you for it (probably exorbitantly.....)
Hello,Hello!
Could you please help me?
My serial is HY6BN06179
Part is 281853HN4C
And date 161130
Thank you very much in advance!!
You can also get it online, https://radiocodeford.com/nissan-radio-code for exampleHello!
Part is 281853HN4C
And date 161130
Hi, your code is 1104Mine is BP538469508628 any help would be greatly appreciated
Code for bp334947254455 is 6631I have Nissan micro same problem bp334947254455
The code for BP334958120678 is 0692Hi can someone help with my wife's radio code please brought it 2nd hand guy is refusing to help with code or give book to us Nissan said they can't help us for some reason
BP334958120678
Ash
Hi, your code is 3877Could someone please help me also, serial no. BP538469477233.
Many thanks
Hi, your code is 2329Please help mine is BP334958148756
Hi, unfortunately is not possible to get code for this type for free. You can check eBay or https://radiocodeford.com/nissan-radio-codeHi, my radio code is locked after i had to replace my car battery. I would really appreciate if someone could find me a code please? Thank you.
Serial: DW43N23669
Part: 28185 3HN4B
Date: 14.03.14.
Many thanks in advance.
Sahil
Unfotunatly it is also not possible to get the code for it for free, I recommend your eBay or the site I posted in the post above.Could you please help me get the code for my radio. Mine is:
CL0930C9135448
PN-3201M-B
