Just an update on some of the spec in my car...
Engine - 1275, Micra Challenge cams, big injectors, fse regulator, gpa airbox, janspeed 4branch and decat silencer, new Humpris stainless comp exhaust, nismo mounts, 118bhp 96@wheels
Box - 5.1 cwp, gripper steel LSD , quick shift gearstick
Suspension - bilstein cup/gravel coilovers, camber washers, roller bearing alloy top mounts, rear- cup/challenge springs, spax shocks, full polybushed and brand new nismo rear bushes
Humpris steel light weight flywheel and paddle clutch
Brakes - gtir front brakes with 1144 pads, rear standard beam with standard disc brake setup, braided lines, hydraulic handbrake, bias valve
Shell - fully seam welded shell, 13 point challenge cage with x rear and belt rail, front strut brace,
Full fire system plumbed in and hand held
2 sparco and corbeau professional seats, 6 point harnesses, alloy wheel boss with Momo limited edition Martini Racing steering wheel, various relays inside the car.
And more that ive probably forgotten...
