Well there isnt much progression from forced induction, atleast with N/A tuning you can go forced when you've run out of things to do!
providing you havent done N/A only things to the engine that would cause problems should you decide to go forced.
showing my ignorance here i know, but what n/a engine modifications would cause problems when converting to f/i..?..
increased compression mainly... i think
there is only so big the turbo can get!!!
I bet a fraction of anyone here really knows anything about na or turbo tuning. They both have their places just NA is more easily accessible to those with smaller budgets...
why not super turbo with nos?
thats what i want
Turbo system at the very least will set you back £1500 if you do everything yourself from fitting, welding (full exhaust system, i/c etc) and tuning. Mine has cost in that region but in my opinion closer t £1100.
You can easily spend that on a N/A car, throttle bodies and a stand alone ecu would inc setting up would just about cost that.
Oh Micra Pete, why does this thread make you cry?
cheers Paul
nitrous will still need to be mapped, it's not plug and play. anaverage nitrous kit will cost round 200 and then the tank. and a remap for 350 if the stock ecu can handle nos (it should be able to). And not to forget nos is illegal for street use and that you have to refill the tanks. in the long term will cost too much and get you in trouble.
i would like to point out nos is fully legal!as long as you drive within speed limits and dont drive without due care and attention to the road lol i know this because there is no law against the use of nitrous in cars , illegal my back lol if i remember correctly max power mag went to hells gates to prove there was no law governing the use of any gas in an engin and was linked to lpg as a different fuelnitrous will still need to be mapped, it's not plug and play. anaverage nitrous kit will cost round 200 and then the tank. and a remap for 350 if the stock ecu can handle nos (it should be able to). And not to forget nos is illegal for street use and that you have to refill the tanks. in the long term will cost too much and get you in trouble.
Yer its not illegal as long as you dont break the speed limit. Which you probably will if ur using nitrous! :upside:
Thing is with NA cars is even when highly tuned they feel utterly gutless. I drove a new ish Celica the higher powered version, it did go fast when pushed into the cams but it felt mighty slow out of it.
