6147Hi
Its been a while but managed to check the number on the back of the stereo and its a different serial number to that on the card ? hence why the code didnt work. Ive started a new thread to find a good code now but heres a pic if your still helping.View attachment 60010
Hi
Hi, the code that you need would appear to be 0978........Hi Guys,
Need help. Lost Code to my K12 Micra after changing battery.
All I have is following info:
BP5384 7 1220414
7 645 384 318
Any chance to get a code?
Hugs and Kisses
K
Hi Guy, posts crossed, my software only gave one code instead of the usual two, the second code usually starting with zero. I suspect both 8978 and 0978 will work....8978.
Hi @John_D Thanks a lot, i suspect yours might be correct too...might just disconnect the battery and give it a shot as wellHi Guy, posts crossed, my software only gave one code instead of the usual two, the second code usually starting with zero. I suspect both 8978 and 0978 will work....
Hi, try 7429 or 1429..........Hi Everyone.
I’m wondering if you can help me I need a code for my K12 Micra radio after changing the battery. I have the following information on the picture below. If anyone could help me with a code it would be greatly appreciated. Thank you.
Thank you so much it has worked. I really appreciate your help.Hi, try 7429 or 1429..........
Hi, try 4470 or 0470.......Good day
Please help, I do not have a clue what my code is, the password is BP334947273327. Nissan Micra 2004.
I can only supply codes for radios made by BlauPunkt (indicated by a serial number starting with 'BP' followed by a further 12 numbers).................Is it possible to have radio code please ? My number is :
Serial number 2330310
Divice number 7612830023
Nissan Micra 2007
Sadly I can't even unlock the Blaupunkt satnav ones that start with 'BP', where the first three of the following numbers are '000'all right then,so no chance to unlock my sta nav radio
Hi JohnHi, try 4470 or 0470.......
Hi, try 6855 or 0855........hi is it possible to have radio code please ? Battery changed do not have code
model micra K-12 2004
BP334947256817
7643349318
Sorry can't help, your radio made by Daewoo, I can only supply codes for BlauPunkt manufactured units...Hi,
Is it possible for a radio code?
Ive recently bought the car from the dealer but can't get back till friday for them to put the code in and couldn't give me it over the phone
Its a Micra Visia
SERIAL: DW52N12407
PART: 28185 3HN4C
PROD DATE: 15 02 27
Thank you![]()
Sorry can't help, your radio made by Daewoo, I can only supply codes for BlauPunkt manufactured units...![]()
Hi, try 9811 or 1811............Hi, can anyone help me with a radio code for my
K-12 micra 2007
Blaupunkt model BP538461722727
Serial 7645384318
Thanks in advance
You're an absolute STAR, Thank youHi, try 9811 or 1811............
Hi, try 7442 or 1442.......Hi can anyone give me a PIN?.. I had a new starter motor put in my Micra 1.1 S and after my radio kept asking for a PIN. I took the radio out and this is the only number on it. BP536258408697. 59700013209 . I’m really sorry if I’ve posted in the wrong place,
Thank you in advance
Hi, try 9731 or 1731.......Hi,
I have bought the without radio code and it's locked now.
My serial number is
BP536556444315
Can you help?
Marek
Hi,Hi, try 9731 or 1731.......
Hi, try 4730 or 0730.....Hi everyone!
I will realy apreciate is someone could help me with my radio code for
Serial no: BP334947339926
Hope you will be able to help!
Thanks in advance!
Alina
Dear John! Thank you so much! It was 4730! xxxxxHi, try 4730 or 0730.....
Hi, try 6467 or 0467...........Hi, could some one help me please i need a radio code for a K12,
Serial number is :
815 BP5389 6 2412580
Or
7 645 389 618
Im not sure which number is the serail number
this is picture of the serial numberAnyone help me with my radio code for a Nissan Micra 2008
serial code is PP3000MB 0005796
I can only supply codes for radios manufactured by BlauPunkt, not radios made for Nissan by Clarion, Daiwoo or Fujitsu.....this is picture of the serial number
