Hi I've changed battery and tried the safety number thinking that was the code to no avail. Any help appreciated
BP5387 61139422
BP5387 61139422
Not sure what your 'Safety Number' is but the code you need is 6175 or 0175Hi I've changed battery and tried the safety number thinking that was the code to no avail. Any help appreciated
BP5387 61139422
Yeh the safety number is 6175 but not working. It's locked at the moment so not sure how to resolve it apart from trying 0175.Not sure what your 'Safety Number' is but the code you need is 6175 or 0175
Define 'Locked'.....Yeh the safety number is 6175 but not working. It's locked at the moment so not sure how to resolve it apart from trying 0175.
Just for the 1 hour as I tried 6175 3 times with no success.Define 'Locked'.....
Perhaps someone has changed the radio at sometime. If it still fails you will need to remove the radio and check that the serial number matches the one on the paperwork.I'll try again but it's on the card with the book
Ok mate thanks for your help on this much appreciated ?Perhaps someone has changed the radio at sometime. If it still fails you will need to remove the radio and check that the serial number matches the one on the paperwork.
No problems, if it does turn out to be a different serial number, post the new one and I'll give you the code for it.Ok mate thanks for your help on this much appreciated ?
Hi, try 4459, but if that fails 0459Hi, does anyone have the code for my stereo unit?
Here are the codes:
BP538467185485
7645384318
Well if the serial number really starts with 'BG' as you have written, then no, I can't help.Hey! Can anyone plz help with a lost radiocode on a nissan micra -04
BG234746064288
7 642 347 318
Many thanks![]()
A yea, was a typo, sorry about that. Code worked perfect, thanks alot for your helpWell if the serial number really starts with 'BG' as you have written, then no, I can't help.
However if it is a typo and really starts with 'BP' (and you haven't made any more errors with the numbers) then your unlock code is 1956...
Hi, try 9841, or if that fails 1841.....Hi,
Hope you can help me to find the code
BP5389 7 1335384
7 645 389 318
Thanks in advance![]()
Thx a lot, made my day!Hi, try 9841, or if that fails 1841.....
I have a software program that decodes Blaupunkt radios from the serial numberThx a lot, made my day!
Out of curiosity, how do you get those codes ?
Hi, long time reader first time posterI have a software program that decodes Blaupunkt radios from the serial number![]()
Hi, try 2817, or if that fails 0817....Hi, long time reader first time poster
BP234732031392
7642347318
Many thanks
You will be pleased to know that the engraved 'BP' number is what is needed and your unlock code is 6940 or 0940.....Hi. Really new micra k12 owner and researcher
Firstly thanks to all who helps others in forum.
I have a k12 1.2 80hp sport. And have a problem with my radio. I need to get code but the thing that I do not have is sn code sticker behind the radio.
I have the code on the radio metal plate on right side: bp536258427902
And a code by starting with 8...
on left side: 8 635 123 392.0
on behind: 8 635 123 542
Don’t know which one is correct; or is this ok instead of SN by starting with 7...
Could anyone help me to find it?
Thanks in advance.
Thanks John.You will be pleased to know that the engraved 'BP' number is what is needed and your unlock code is 6940 or 0940.....
6940 is ok. Thanks a lot.Thanks John.
You must be the unlocker of the forum
I am going to try this code(s) early morning. Will be telling how it goes..
No problems, try 3666 or 1666......Looked everywhere for a free code generator, but no luck.
Can anyone here help please?
BP234632006805
7642346318
Hi, try 6871 or 0871......Hi John_D
My friend had the same problem than me and he needs a code for his radio
BP 538789963541.
Could you help us with the code. Many thanks.
Hi, try 7418 or 1418Hi
Could you help with my k12, i need radio code please.
Serial is
BP234631985637
7 642 346 318
Thanks, it worked!Hi, try 7418 or 1418
Try 9856 or 1586......Hi, Would anyone be able to help me out with a code for my stereo, the battery went flat and the code wasn't in my service book
BP538962393403
7 645 389 318
Thanks!
Try 2194 or 0194..........Hello everybody! Can anyone please help me find the code for my wife's Micra? I would much appreciate this. Thank you very much!
BP538469469295
7645384318
Thanks for this John, but neither of those codes workedTry 9856 or 1586......
Define 'dont work' , have you got the display 'CODE' on the radio before entering the code and if so what button are you pressing after entering the code to activate it?Thanks for this John, but neither of those codes worked
1653 seems to be the answer to your prayers........Hi
Could you help me with a code following a new battery please?
BP5387 6112 9160
Ian
HiOk mate thanks for your help on this much appreciated ?
