From that information, probably only a Nissan Main Dealer (at an exorbitant price.....)
ok thanksI can only supply codes for radios manufactured by BlauPunkt, not radios made for Nissan by Clarion, Daiwoo or Fujitsu.....![]()
Afternoon John_D can you provide a radio code for a nissan K12 2009. Radio serial number is BP7383 9878 3092I can only supply codes for radios manufactured by BlauPunkt, not radios made for Nissan by Clarion, Daiwoo or Fujitsu.....![]()
No problemsAfternoon John_D can you provide a radio code for a nissan K12 2009. Radio serial number is BP7383 9878 3092
Cheers in advance![]()
Fanbloodytastic. Worked a treat cheersNo problemsTry 5214 or 1214.......
No problems, nice easy one to remember, code would appear to be 1930......Hey all, so my mother in laws car battery went flat in the freezing cold so I changed it out and it has reset the radio, can anyone help me with my radio code?
SERIAL = BP538458814146
Thanks in advance.
Thanks very much for such a quick response. I actually had that code and tried to put it in but did not work. The manual stated to press T/A to confirm but when I pressed that it did not go through. Ever come across this problem before??No problems, nice easy one to remember, code would appear to be 1930......
Put the code in and when you get to the point that asks for confirmation try pressing the 'UP' arrow button, if nothing happens try the other non number buttons on the radio, one will work.Thanks very much for such a quick response. I actually had that code and tried to put it in but did not work. The manual stated to press T/A to confirm but when I pressed that it did not go through. Ever come across this problem before??
No problems, somehow missed your earlier post, things have been a bit hectic round here recently, No2 son got married on Friday and things are only now slowly getting back to normalSorry my previous post was a bit too succinct and may have looked a little rude.
No I haven't nicked a radio. I bought my wife a 2010 K12 and no one had the radio code. Shes been driving it for the last 8 months quieter than a Tesla.
I've eventually taken the radio out and got the serial number. Would someone be able to give me the code please.
The serial number is BP7383 A 9408477
Thank you
Hi, try 5860 or 1860.....Hi all, I've inherited a Nissan Micra (K12 I think!) and the stereo is locked.
The serial number is: BP334936373321
Nissan MM CD-K 7643349318
Any help would be fantastic!
Thanks,
C
Hi,
I recently changed the battery to my Micra N-tec 2009 and the radio won't work and it asks for a code...
That is a great tip mika,have not once lost the code yet here without this. But just made me think that method would save all my radio setting as well as the code for the radio. I know I have a 12v supply as a spare just needs a cable system to hook up.Somewhere on this thread should be permanent instructions, feed 12V from other power source to cables, while disconnecting/changing battery!
Which should be common sense! That's how we change car batteries here in the Land of the Finns.
No more loosing codes or settings on radios![]()
Even a 9V battery will do the trick...That is a great tip mika,have not once lost the code yet here without this. But just made me think that method would save all my radio setting as well as the code for the radio. I know I have a 12v supply as a spare just needs a cable system to hook up.
Not sure if the accessory port would work.Just that's where I was originally going to place my booster if and when needed.
Sent from my ASUS_T00P using Micra Sports Club mobile app
If the radio is turned OFF (so there is no current drain in it) when the battery is disconnected, thecharge in the internal capacitors will hold all the memory functions, including the security code, for at least a minute.........so you have plenty of time to disconnect the old battery and clip your back up PP3 into place, or as I do just get everything ready and lined up and make sure the new battery is reconnected within that time frame.....Even a 9V battery will do the trick...
Hi, try 6905 or 0905....Someone can also help me with a code for cd player at a nissan micra k12? BP234732042313 \\\ 7 642 347 318
Hi Gavin, try 8538 or 0538....Hi MSC Forum People,
If you are able, please can you help me with an unlock code for this Blaupunkt CD radio.
BP538471220372 / 7 645 384 318
It's for my Nissan Micra, I had to change the big fuse on the battery. So after I did that and switched the car on again, the radio wanted a code, which I don't have. So I then had to remove the radio from the car to find the serial number. Hopefully you can help.
Kind regards,
Gavin Newell
Post a picture of the radio to see if it can be identified as a BlauPunkt unit.... On my 06 K12 CD changer unit there was no sticker with the 'BP' serial number , but it was engraved on either the side or the back of the actual unit....Hi, not sure if I should tack onto this thread or ask as a new question so apologies if in wrong area.
I had to get a new battery fitted on my '06 Micra - and you can probably guess where this is going! I bought the car second hand and don't have manual or any codes for this. Have taken out the radio to hunt for the 'BP' code but I don't appear to have one? No sticker or details on there, all I've got is a printout sellotaped to the side of the radio with the following codes:
K122166232
ZH-D912
28 185 BC41A
Any help appreciated.
Hi, try 4183 or 0183.......Hello, i have problem with nissan micra radio code i cant find it, can you help me please?!.
Radio S/n: BP538471194336
7645384318 NissanMMRCD-G
If you need anything else please tell me.
Túl sok szám a „BP” után, csak 12, NEM 13 legyen.Szia tudnék valaki segíteni nekem a közelmúltban vásárolt mikroszkópban, és nem kaptam meg a BP7383878164038 rádiós tippet: HP3451C előre köszönöm a segítségét
That number gives code as 2034 or 0034......bp738387816438
Thanks alot!!!Hi, try 4183 or 0183.......
Looks like I missed this oneGood afternoon,
battery went flat on mine would you be able to help please.
S/N BP3349 4 7305612
Many thanks
Not enough numbers after the 'BP' in the serial number, should be 12 numbers not 10.............Hello guys, really need some help
BP 7647383318
Nissan part number 281859U00A.
Thanks in advance
I found this stamp. Is there another bo nr that i should search?Not enough numbers after the 'BP' in the serial number, should be 12 numbers not 10.............
