K12 Radio Codes
The numbers are Bp334947308472 and 7643349318.
Thanks in advance
Hi Amy,
The code you need is 3556, or if that doesn't work, 1556.
The only way you can get the code from the BP serial number is by using a special software decoding program, so there was no way you could work it out yourself from the numbers on the radio...
Yo peepz!
I just got my hands on one of those K12 CD players stereos, the Blaupunkt MM CD-K or summat (The one with the white selector buttons either side)
I know you guys are pretty good at getting codes, how, I'll never know. But if I put up some numbers wold someone be able to find me the code please?
I understand its these numbers you need:
BP234631954219
There is also a number on a sticker at the back under the 'Nissan MM CD-K';
7 642 346 318
Cheers guys!
Yo peepz!
BP234631954219
7 642 346 318
Cheers guys!
The answer to your prayers is (most likely) 5152, or 1152 if that fails;)
Hi John, wonder if you could maybe help with my code prob. Just bought a Micra for daught first car and its fab...apart from no bloody code, managed to get stereo out and find the serial number which is BP536258429315.
Regards
Hello,
Recently I have bought a 2003 K12 Micra. Unfortunately the radio is asking for the code and after checking all of the paperwork with the car, no one has written it down.
I've had the radio out to get the codes:
BP234732021889
7 642 347 318
It would be a great help if someone could tell me the code to get it working.
Thanks.
(Sorry if this is a duplicate post, my original post still says it need to be moderated and cannot be seen after 2 weeks)
Hello,
BP234732021889
7 642 347 318
Thanks.
Try 9523 or if that fails 1523
Hi there,
I need the code for radio serial number BP334936391799
The model number is 8635123392
Like a few others in this thread the model number doesn't start with 76.
I'd be most grateful for any help :)
Excellent stuff JohnD, just fitted and tried, works like a charm! Had to wait for '1 HOUR' as the radio said but cleaned up the Micra left it running and then boom, 0000, code inputted and have CHOONZ in the "new" 2003 K11 Micra.
Hi John_D,
I've got the same problem as others. Can you please help me to get the code for my CD/Radio for Nissan Micra.
Serial and model numbers are:
BP538775751649
7645387618
Many thanks
Hi guys ! Can anyone help me to get my code for my radio ,Nissan micra 2006 all I have
863512354201 and K122071003
Many thanks
Hi there,
BP5365 56447781
I have the safe number, the nr is 3468 but is not working.
Because I tried a lots of times the system locked saying to try after one hour.
Anyone could me help to sort this problem. Many thanks...
Hi there,
BP5365 56447781
Well that is the correct code, though an alternative of 1468 comes up as well...How are you inputting it?
Does this help?
Well if the first number starts with 'BP' then your code is 0241.......
If the radio is not a 'Blau Punkt' one then I cant help...
Hi there, I’ve recently had my battery changed and it’s reset the radio and I have no idea what the code is to get it working again. I’ve got as far as getting the serial number off the back of the radio but now I’m stuck! Please help if you can and if this is the right page for it.
Thanks in advance:)
Thanks in advance:)
Also dealership have just quoted me £68! That’s extortionate!
Regards
This one seems to have gone under the radar... Code is 4536 or if that fails 0536...
Hi there,
Seem to have missed this one.......Code is 9720 or 1720....
Hello,
I recently bought a K12 1.4 SVE 2004. Radio not working.
Serial: BP334947313766
764334931
Can you please help me with the code?
Thank you
Hello everyone. I have a problem with the radio. I do not know what my code is. Can you help me with decoding? Thank you all !!! My serial numb is BP234631982840 , 7642346318 nissan MM CD-K
Hi, The code is 7174, or if that fails 1174.....
Can anyone help please?
Hi, had to do an emergency battery change and as usual there is no radio code to be found in the car or manuals. Have been given a code (9969) by an on-line service which doesn't work!
the unit is a BP 7612 830 003
serial number BP 000394685828
Thanks in anticipation.
Well I've never seen a serial number starting with '000' before, but the software seems to recognise it and comes up with the code 9969, with1969 as the alternative.......
Would have expected the first number that you posted to be the correct serial number but it is too short, needs to be 12 digits after 'BP'......
Hi peeps
I have a radio code problem for my 2004 k12 1.4 Micra can anyone help please?
BP 3349 4 7300 781
7643 349 318
Many thanks in advance
Al
