Try 6938 or 0938Hi could anyone help with a code please?
2006 micra
BP234756423452
7642347318
Majk
2006 micra
BP234756423452
7642347318
Majk
Thank you John, the 2029 worked!Try 2029 or if that fails 0029
Hi, try 5231 or 1231...Could anyone help with a micra radio code please?
BP334958118060
7643349318
Thankyou in advance!
Legend. Thankyou!Hi, try 5231 or 1231...
Try 5213 or 1213.Hi, I have a K12 Micra (2004 model) - had to have a new starter motor put in and the radio now asking for code.
It didn't have a sticker on the back so I've got this from the metal casing:
Serial: BP334947280593
Part: 8635123392.0 (this number is on the side)
Part: 8635123393 (this one on the rear)
So I'm not 100% on which part number is used. I can attach pictures if needed.
It's currently stuck on "Wait 1hr" do I just leave the engine running until it clears..?
Try 5213 or 1213.
As far as the 'Wait 1hr' message, easiest option is turn the radio ON and go for a drive till the message disappears..
Hi, try 3695, or if that fails 1695Hello everyone. My battery died and i dont have the code. Can any one help. Nissan Micra K12
BP538469488696
7645384318
Thnx
Hi the code you need appears to be 0735. If you have the 'Wait 1 Hour' message, AFAIK you need to start the car, switch the radio ON, then go for a drive till the message disappears......Hello,
I'd be really grateful if someone could help me with my radio code - it hasn't worked since I got the car!
It's BP 3349 3 6367460.
Also, am I correct that you switch the ignition to accessories position for 1 hour, without starting the engine?
Many thanks for your help.
No problems, the accessories position switch fix is a new one on me, very useful information.Thank you so much - code worked perfectly!
I just had to put the ignition switch to the accessories position for one hour without starting the engine, and after one rather boring hour it allowed for the code to be entered.
Thanks again - saves me listening to the droning diesel engine...
Where did you get 5713 and 1713 from? Just checked your serial number in the de-coder and it came out as 9638 and 1638 as a possible alternative if the first one didn't work....Hello guys,
Could anyone help me with radio code please?
BP234631956603
7 642 346 318
5713 and 1713 didn't work, needed to wait an hour.
Thanks upfront guys!
These codes are specific to the serial number of the radio, some one else's codes will not work.....
http://www.micrak12.com/stereo.htmMine has gone too how do i get the radio out please?, also I have posted a thread about air in the system and it not starting properly, TIA
Very clear and Step-by-step
Verstuurd vanaf mijn SM-G950F met Tapatalk
DO NOT remove the A pillar trims and complete dashboard top as shown in that video it is NOT necessary! Follow THIS VIDEO for the easy way to get access to the top centre bolt....Thank you - Tak
I will have a go tomorrow
I think you ll be losing a bolt fairly easy? Especially the top 3 ones.DO NOT remove the A pillar trims and complete dashboard top as shown in that video it is NOT necessary! Follow THIS VIDEO for the easy way to get access to the top centre bolt....
You only have to remove the centre one you do not have to remove the bracket from the radio, you get the radio out with the bracket still attached, I didn't have a problem (I used a 1/4" drive socket with a 75mm extension) and I'm 70!I think you ll be losing a bolt fairly easy? Especially the top 3 ones.
Taking of the A pillar trims and the top cover isnt that hard. Better be save than sorry.
Hi, 0295 should get you back in her good books again.Evening folks, my better half recently passed her test and treated herself to a K12 automagic which has the Blaupunkt stereo and I managed to mess things up when installing her Parrot Bluetooth kit by having the power out for too long it would seem.
Could I be a PITA and ask for the code? The sticker on the rear of the unit reads: BP234732041689 and t'other code is 7642347318.
Thanks in advance!
John you legend, that's done the trick perfectly!Hi, 0295 should get you back in her good books again.
Hi, try 2056 or 0056 if the first one doesn't work2005 Micra s need radio code if anyone can help .
Been without since I bought the car 3 months ago
Sn is bp334958116884
Mn is. 7643349318
Please help tired of the silence now
Somewhere in this page should be instructions, feed 12V from other power source to cables, while chancing battery!Hi, I've had to change the car battery of my 2006 Micra and now the radio won't work. I can't find a radio code anywhere...
Thanks Mika, I must admit I hadn't thought about the radio when my battery was flat but will think of it if I'm in the same situation again. If you have the code, I'd be grateful if you could help me.Somewhere in this page should be instructions, feed 12V from other power source to cables, while chancing battery!
Which should be common sense! That's how we change car batteries here in the Land of the Finns.
Not loosing codes or setting in radio.
Hi, try 9812, or if that doesn't work 1812. Oh, and write the working code down in more than one place (one kept in the car somewhere and again at home with the car documents )Hi, I've had to change the car battery of my 2006 Micra and now the radio won't work. I can't find a radio code anywhere.
The numbers on the radio are:
BP5387 6 9678235
7 645 387 318
I'd be very very grateful if anyone can tell me the correct code. Thank you.
Thank you thank you thank you! I am so grateful to you!Hi, try 9812, or if that doesn't work 1812. Oh, and write the working code down in more than one place (one kept in the car somewhere and again at home with the car documents )
Hi Paul, try 8516, but if in the unlikely event that doesn't work, 0516 is the alternative code.Hi I’m afraid I’m another micra noob that bought a k12 without a radio code and changed the battery not knowing it would lose it! I have the serial number from the radio which is BP234732037632. Is there someone that could help please and I will be sure to write number down and keep it.
Paul.
Hi, no problems, try 9758, or if that fails 1758Hi John,
I have a Nissan Micra 2004 model, owned for 4 years and yesterday I bought a new battery.
I installed the battery and forgot it's going to require the radio code. I have misplaced the radio code.
So I removed the radio and it does not have a sticker on back however the serial and part numbers are engraved on the radio as follows:
BP334947258872 engraved on right side radio
8 635 123 393 0 engraved on back of radio
8 635 123 392 0 engraved on left side of radio
Will really appreciate if you can help me out.
Hi John, thanks for that I’ll give it a try on Sunday as I’m busy until then.Hi Paul, try 8516, but if in the unlikely event that doesn't work, 0516 is the alternative code.
