Custom Digital Turbo gauge, anybody want to try?
pjg1979
THIS IS MY BOOMSTICK!
Hi guys n' gals, this is mainly for those with turbo'd micra's.
I have been working on a digital turbo gauge, that turns on as soon as you turn the ignition onto the first click.
The dimensions are in the images attached, the backlight is blue and you would need to do some modifying to mount it somewhere. There are three buttons two of which you won't need. The Main one is the M this changes the reading to BAR, KPA or PSI depending on what you prefer.
Just wondering would anybody be interested in testing it, I'm sure it won't knacker your turbo as it's just a gauge. it also measures in 0.5 in PSI for example if you were running at 7 psi via a normal gauge it would show 6.5, 7.0 or 7.5 which is more acurate.
What do you think? I only have one.
does this only measure positive pressure?
im pming you now as i have a couple of questions but dont want to clog the thread
As far as I'm aware, unsure how you get negative pressure, lol.
The Gauge does do the calculations between PSI to BAR to KPA as well.
If you look at the protruding circle around the the display and buttons, this can be left and the rest cut off as I have made two today given one to my Renault 5 Turbo mate and will be having a look this Sunday, fingers crossed.
Simple to wire as well.
