h701micra
Deactivated Account
Yea I made a dumb last nightaye, you jack the axle up (compress the spring) then fit the shorter shock![]()
I realised after I'd said it
it will make it a bit skittish luca, but should,nt be any firmer (unless you added more preload than the weight of the car)yeah, that was the case, had my mate sit in the boot to load it enough to get the bolts in! haha, may that be the very stiff ride?
If you have more preload than vehicle weight, cutting the spring won't lower your car UP TO A POINT. If you cut 1/4 a coil at a time until the car sits JUST lower than it does now you'll be at just less than vehicle weight preload. Stiffer springs will result from the cutting whichwill keep ride comfy with toolbox, bit may make damping inadaquate.think there may be slightly more preload than the weight of the car.. if i have to boot empty then its very bumpy, but if i stick my toolbox in the back then it improves slightly..
only problem is that if i cut any more off, won't it lower the car more? as iv got the ride height to where i want it really
the spring needs to be able to oscillate down and up really luca, so if you have equal preload/corner weight it cant lift at all eh (twill lift the inside rear wheel nicely thothink there may be slightly more preload than the weight of the car.. if i have to boot empty then its very bumpy, but if i stick my toolbox in the back then it improves slightly..
Not where shorter shocks are concernedyou'll be at just less than vehicle weight preload
Not a wise idea... only make it stiffer and more uncomfortable?il try cutting the springs a tad more soon![]()
stop being a little bitchdam slippery when you get their,,,,,,,,,,be careful you could slide of the top,,,,,,,,,dont rush to get their ,,,,,thash what i say
+1corsa mounts are a far safer option imo luca![]()
