So basically sleeve the shaft with washers, then one big washer, larger than the hole which will clamp it all together??
Ahh, was given the option to get the rubber with bearing, but knew there was already a bearing on it so just got the top mountNormally they have large rubber mounts before the top cup unlike ours that's where the size difference is
Where am I meant to get a steel sleeve with a hole that size but the outer large enough?You could do. I'd personally get a steel sleeve on it
You could doThen another tube 15mm I.d upto the next thickest o.d?
Why?
Because thats the bumpstopWhy?
Or do you mean in place of the would-rubber locater
Bumpstop is in the spring on shaft :/Because thats the bumpstop![]()
That rubber attached to your top mount is the rubber locater I was on about.here was mine thats the top of it, and it impacts with that rubber (without that the spring cup will punch though the top !)
I have aeound 15mm poking outthe top of minei guess he could actually use the top spring cup instead, as long as it is suspended about 5mm below the rubber when assembled (he would have a lot of thread sticking out the top tho !)
the bearing fits down into the rubber (that way up in the pic) then the alloy bit goes on next (turned over in the pic)![]()
yeh man@frank are these corsa top mounts I take it?
Looks like a plan Luca
yeh manand i hope you have power steering luca
you need an air gap between that rubber buffer i pointed out ehDon't say that.... I don't, how's that??
WRONG INFO,,,,,,,,,,,,,once their on your stuck with them for a little whileyou could ask the previous owner how it rode with this set up,,,,,,i think he removed it sharpish![]()
but yeh try before you buy
Thats why my white car had bonnet raisers hahaif you have too much thread showing you get 2 nipples appear on the top of your bonnet luca![]()
