Haha, other threads.. The ones to raise and lower the car hahaha
But will the washer fit through turret hole
Not possible nor safeAnybody used the corsa springs on the rear?
if you wantShould I ask them to try and do the camber?
my guess would be the 12v and earth to power the unit luca, and the common is the motor + wire, and the nc and no are the pulse and pause outlet wires (you just need the pause one eh)making slow but steady progress ! so one thing thats bugging me is the fact that i don't have intermittent wipers... i know it sounds very fussy.. but it bugs the hell out of me as they are either constant on or off
soooo... i went to maplin and bought a intermittent timer kit
http://www.maplin.co.uk/p/mk111-adjustable-timer-kit-with-relay-output-vt27e
So now i need some help wiring it hmm... it has 5 connectors on it, 12v, earth, Common, NC and NO... so what wires would go where would any of you know?? i want to do it in a way that on the first stalk position it is intermittent, then the second stalk position is as normal
I've just woken up, I'll look a bit later lolthere,s a pdf circuit diag linked on the maplin questions andy (german tho)
aye, and nc for pause eh http://www.velleman.eu/downloads/0/minikits/manuals/manual_mk111.pdfThe timer circuict controls how long the coil is engaged and disengaged for, which pulls the switch and causes intemitent feed to the wiper motor. I'm guessing there is a couple of potentiometers (screw adjustments) to adjust the on/off balance and the time for one complete cycle
NO= normally open
NC= normally closed
common =switch power in
I THINK (without looking at the instructions) that you would a have 12v feed to the common, then from the NO to the wiper motor positive. Then, have a switched feed to the Positive and a wire from earth to an earthing point. Switching the switch will engage the intermittent feature. There should be no problem having the intermittent switched on AND the wipers on at the stalk
(if, with the wipers off at the stalk, switching the intermittent switch doesn't cause the wiper to move immediately, swap the NO wire to NC)
Want to do a rough wiring diagram for future reference?Iv Sussed it!
So here's how it worked best,
12v feed on a switch to the 12v on the board, ground is obviously just grounded.
Then the green with red stripe wire is the wire for the first position, cut that, the wire from the stalk goes into NO and the other side that goes to the motor goes to COM.
Then to get the wipers to automatically go back to the start position you get a feed from the orange with black stripe wire to go to NC... This way even if you switch the wipers off or the pulse timing is slightly out of sync.. It will always go back to the correct position.
Want to do a rough wiring diagram for future reference?![]()
Corsa b lowering shocks are very stiff, no getting away with that. If they were stock corsa shocks it might have been you were sitting on the bumpstops, bit its just very stiff shocks.They are corsa b lowering shocks and I'm using the bump stops that they came with, have I done it wrong??
How many coils in total from the rear? :/darn, way to stiff at the moment!!
Yeahow many have been taken off?
aye, you jack the axle up (compress the spring) then fit the shorter shockCan you even preload a k11 spring?
