To be honest Stani, you're engine setup's so custom, you're choosing on which brand you like the sound of really although Mobil Super 3000 has a pretty decent rep. if you Google 'Bob is the oil guy forum', I guarantee you won't leave the house all afternoon.
those comp readings are absolutely perfectdunno if the plugs are a notch slightly towards lean? but the insulators almost brown enough
i bet the headbolts go another 1/8 th of a turn now the gaskets have compressed stani.
btw, trying to keep up with you coming back from jae has finally free,d off my little end loli,ve had a little clatter noise for 2 or 3 minutes after every startup since i fitted this engine a couple of months ago, and i guessed it was the tight wristpin that i should have sorted out before assembly (but could,nt be arsed) its disappeared since that sunday
phht 70 my arse lolOk well ill redo them before mapping. No need to drain coolant? How about when engine hot or cold? And i guess you may never know what it is, do you do alot of 70mph journeys? Maybe thats what it needed....
Nissan certainly adopt the 'pull the customer's pants down' approach to charging![]()
black/white is the signal one aint it mate (not 12v)
Mine may have turned up with nout wrong ....just saying![]()
Sent from my NOVO7PALADIN using Tapatalk 2
By any chance did you have a packet filled with asbestos lol. And yes hand me the salt. I think the wrapped them too tight.
Haha i did get tempted to eat it as well.That was asbestos? I ate it......see you at JAE 3067 in my future life![]()
Bought the £20 new distributor from ebay but also come with a broken cap. Not bothered so long as it works
How much boost you running? Are you not running a dump valve/recirc valve?
mine was the same asbestos wrapping too. overall not very suitable for such a fragile product but good thing mines fine too![]()
Ohhh # and a half pistons.... know the feeling.1psi sometimes 2psi, and thats only at 1/4 throttle as anymore id have 3 1/2 pistons lol and i hope to run a recirc valve later, dump valve used to work but then just got faulty and cant be assed with it happening again
thats an idea,,,,,,,,,like the tyre paint may suit the back too
Hey stani, how come your selling the beast?
