Aaaaaand i'm back! project had to be put on hold for quiet some time, on the left is a 1.2 from -89 (rusty piece of ****) which will be donating interior, bumpers etc to do facelift on the 1.0 -86
Started stripping the -86 down entierly to respray etc, might aswell do it properly
Just found out that CG10DE with the 23710 99B00 ECU (which is what i have) is NIStune compatible but CGA3DE is not, so i wont be changing it for a CGA3DE.
Now i have missplaced my papers with ECU pinout :/ anyone have any good pictures?
Abit more progress, going to clean the engine of, give the valvecover som paint etc.
Passenger side enginemount pretty much done, going to weld the little pipes on there, cut away some exess (marked) and then sandblast and paint it.
Facelift finished, had to modify the front as the lower headlight mountings were different. Not sure about this grille tho, maybe with the Nissan badge removed, and some work to remove the holes aswell as the cutouts for wiperarms.
Bought a water separator for the blasting equipment today so i could blast properly, nozzle keept clogging up, then i painted the mount and moved on to blasting beltdiscs.
Also tested the blasting media on a piece of aluminium, worked good, gets a slightly rough surface that the paint will grab onto HARD on the valvecover when i blast that.
