good luck I didn't get it fittedYou manage to get it free you d***, fit it tonight and it won't be there in the morning. I want one![]()
I would get on it for helpingWe should have a thread with peoples locations and the skills they are willing to lend to help people out!
I still laugh to this day when I got an MOT fail for excessively corroded rear brake lines that turned out to be a build up of mud on the pipe. I look it back, demanded a re-test and walked away with a pass shortly afterwards
I've had nasty sill jobs done for not a lot on previous dailys, but the work has been quite a hack job.....just a plate slap welded on on and a gob of underseal sprayed over.
Shame your not closer matey, i could have welded it up.
There must be someone on here whos local to you who can help who is local to you.
Ouch, thats wrecked the door !not what i did bit this happened to my nissan today
Sent from... My phone
Kill them all, the cheese eating surrender monkeys.Dam French car drivers :|
I would of kicked his door in..lucky enough this is only my daily beater and the tiny dent it left in the door just blended in with the rest of the dents lol
I'll remember not to get on your wrong side then lol...I'd have kicked his....elsewhere LOL
i mess with mine only to try and make it better, hence the new engineLOL.. Dude, don't mess with the Micra![]()
WDIDT ?
got the axle off at last (damn busy at the track lately !) 1 of the bush bolts put up a fight, but it gave in in the end lol
and one of our marshals got me some more corsa pistons, so the shortened chain/high comp n/a project is back on track
Was the 1.0 flywheel lighter belly ? And are you gonna run the 1.0 ecu ?Got the cga3 lump in just need to finish plumbing in the fuel and water pipes the reconect all the electrics
Is there no nats control unit ?I got the key and ring for ingintion barrel too![]()
Yeh they will fit if the pcd is 4x100 and centre bore is 59.1mmWhat size rims are you lot using? And offset. I've got some 14" rims in my shed with +38 offset reckon they would fit a k11
Sent from my GT-I9100 using Tapatalk 2
Belly93 said:just sick of this dam exhaust blowing :/ wouldn't mind a 4-2-1 manifold or something similar, I had help removing and putting the engine back in just so I didn't brake anything
unsure exactly i can hear it tho as i driveWhere's it blowing from?
