I don't no what u call them that hold in the pads the metal cage bit ? They are rare to get from motor factors as its import but lucky waited for mines, thanks to polly and 12h![]()
Yh pad carriers thanks.pad carriers?
turbo diesel with powers? sounds rich![]()
How would Astra 1.7 cdti engine be in a Micra ? Since its Eco
I was thinking coz from petrol to diesel it would defo effect something30 pence tax model? dvla would say "it's that azzydot again, let's hit him with a vic check"
Become un-reliable.How would Astra 1.7 cdti engine be in a Micra ? Since its Eco
Had mines for 2 years without a faultBecome un-reliable.
You mean the hub to carrier, not caliper to carrier don't you.
Been mooching around looking at coilovers, why is it that the Micra ones are so expensive??? when others are only a couple hundred pounds(?)
Think that was the almera gti ones had longer travel if used with micra master cylinder the pulsar ones were fine i think, something to do with almeras having two pots or something?? :s@12h when bleeding the pulsar brakes do I need to do anything for brake pedal will the travel be lower then stock which I have heard ?
I just remember readin something like that on here, probably wrong i dont know hahagti / pulsar /v22 almeras nx 100 are all the same caliper arent they ?? single piston sliding caliper i think its the discs that are larger vented theres were the stopping cooling power is were t
if you have a bigger piston on the caliper say 75 mm on the micra then you switch to gti which have say 125 mm piston you displace more fluid from the master to push said piston that why the brake peddle has more travel to solve this you use a bigger master cylinder ie primera gti it takes workto do this mind again polly p has done this or something simular using a diffrent master
andy
My brother was in car pressing the brake pedal in and out about 20 times getting all the air out when he pushes in all the way down I lock the nipple ? @frank are u using the same set up ?must still have air in them?? are you doing it on your own (ohhh matron) get some one in the car pushin the peddle down while you open n close the bleed nipple
Ok I will try that Tommow againtry pumping the peddle to floor un lock nipple squirt then lock nipple theres air in there i did mine for 10 mins peddle good as new
peddle down unlock lock peddle up repeat
Omg never ? So he sold it and not getting into Micra ? I can't believe this, Frank come backAzzy... Frank is working on diesel astras now, he sold his white micra. Not sure how often he checks this forum anymore
I use one of those none return bleed valves but I suppose if your just using a bit of tubing then it coulddont un lock till the peddle is down or air will get in the system
Yeh my brother was pumping the brakes when it was locked then when I unlocked the nipple he was pressing till most of air is out then pedal on floor then I locked itdont un lock till the peddle is down or air will get in the system
Am using tubing with brake fluid to cover the tube 2 inch so air can't get it, but am gona try this again and see if it clearsI use one of those none return bleed valves but I suppose if your just using a bit of tubing then it could![]()
You've got the calipers installed on the wrong side of the car Azzy.
Bleed nipple needs to be at the top in order to allow the air to vent, as below. Should make things much easier with gravity on your side
Well spotted I never knew that till u all told me, right tommows gona be a mission take everything off, should be ok , thanks everyone for spotting itYou've got the calipers installed on the wrong side of the car Azzy.
Ahh didn't no till they spotted iti can see the letter R on the caliper now
HA HA HA the right caliper IS on the left hand side azzy swap um round bleed um alls well
Yeh that was all done am using copper greaseplus the marking "R" (right hand)
has the guide pins been lubed with rubber grease to keep em sliding smoothly?
How does the one way work out and can I get it from motor factorsI have a one way valve, makes doing it by yourself sooo much easier
Can't I get it from local bulleyes ? Just don't wana wait on eBay timeDoes exactly as the name suggested, I got mine for a couple of quid from ebay
Got hold of one since I got a traders am paying 2.50 poundsDoes exactly as the name suggested, I got mine for a couple of quid from ebay
Ahh not bad price so with this I keep pumping then jump out of car and lock the nipple ?I paid something like that on ebay
Skip to 2:30
