There is no tensioning idlers at all on the second facelift 1.0's.woulda thought to remove any of the belts is just a basic 14mm spanner to loosen the pulley axle nut and then 12mm socket to screw up/down the tensioner to move the pulley & loosen the belt?
Solved the video question, you can easily rotate videos directly in YouTube![]()
For the alternator belt, there's an adjustment mechanism on the alternator so the alternator itself sets the tension.
I think I can see a tensioner bolt on the back of the PAS pump, similar to the one on the alternator but I'd need a really thin wrench to get at it.
Think I've found my setup here: https://www.micra.org.uk/threads/drive-belt-adjustment-water-pump-power-steering-pump.37657/on mine, the auxilary belt tensioner is under the PAS, just have to remove the inner splash guard & wheel for better access, loosen the pulley nut with spanner and adjust the tensioner from beneath.
haynes explains it all
Thought I was going crazy!
If you're using the sj4000 or sjcam as your GoPro copy, then there is a menu setting to flip the image 180deg. You can then mount it upside down but your recording will be correctly orientated.Last few days :-
- Got the front roll cage feet welded up - see blog for more www.mattendean.co.uk
- Removed the now out of date seats, cleaned them up and now provisionally sold them
- Cleaned up the floor, whilst the seats are out and then re-sealed up holes in the floor pan. Also cleaned up other bits which are hard to reach, when the seats are in.
- Played around with lots of camera mounting points for my cheap (but good) GoPro copy camera. Think I have sorted it now, if I can find a way of flipping the images as the camera would be mounted upside down in its current planned location.
- Painted and waxoil'ed up the areas which were welded up.
- Played around finding suitable mounting points for the race rain light, think I have sussed this now (hidden in bumper), and tried mounts for a LED high level 3rd brake light.
There is a tensioner idler on the second facelifts with aircon. The alternator on these is fixed.There is no tensioning idlers at all on the second facelift 1.0's.
They're T10 for the heater controls. I'll have a look tomorrow for you as I've got a non revcounter dash in the garage. Unless someone gets back to you earlier.Without wanting to start a fresh and overdone thread about dash lights how many T5 sized LED's do i need to do the clocks and heater controls in a k11c non rev counter.. I searched and searched and cannot find an answer, Grrrr lol
Thanks mate, i have just seen the 'kit' for changing them says it comes with 8 bulbs but it doesn't specify how many are T5 and how many are T10 so i will keep looking for info until you get back to me thank you![]()
So your second facelift would be like this?There is a tensioner idler on the second facelifts with aircon. The alternator on these is fixed.
I think I need to mount my new camera upside down, and YouTube has a very simple and easy to use rotate function, where you can turn the video through 90' L or R, two clicks right and it is sorted. I suspect i could alter the camera set, but I will use it other places too. This is very simple so will use the YouTube Function.to solve the vertical video syndrome? some handy edit features in ytube
Thanks a lotI used 2 x T10 for heater controls and 5 x T5 for dash.
Sent from my KFTT using Tapatalk
I got spare bolts mateCreated a wanted add but more people come here.....
Help!!! Putting my engine back together and I seem to have lost the 3 long bolts that hold the thermostat part to the head, not the thermostat housing as such but the 90deg bit. See photo for clarification! Any one have some spares, or recently blown up a cg engine?? Thanks in advance
What model of clocks they from I need one my self
No rust on mine Super, nor on my last one.Oh and I am thinking of writing to the Krust people and suggesting they start offering a full dip bath option or full under spray option with Krust for Micra owners.... Great cars, but they do love to rust...
[Q UOTE="Azzydot, post: 728036, member: 15800"]What's it like to have a 2,0 turbo Micra anyone ?
I COULD NOT MAKE THIS UP IF I TRIED AND I DID NOT DREAM THIS!
Today has been surreal I had been working on Steffi Cab all day and at about 7.00pm decided to cruise down St Peter Port town with obviously Steffi's top down with Shakira blasting out "What ever Where ever", drove down a one way street called St Anne's Place and the road was mobbed/blocked (estimate 100+) by wedding guests overflowing from The Old Government House Hotel, mostly posh totty who stopped me and started dancing in the road around me and they would not move!
I played another song which was "Freak", then out of the blue Jenson Button appeared sat/lent on Steffi's bonnet to a roar of laughter (there must be pics of this or selfies somewhere) Jenson used to live in Guernsey! After "Cry Wolf" by AHA and "Blurred Lines" they let me go! I know my taste in music stinks but that's all I had lol!
I have since been told apparently Jenson and David Coulthard were over for a wedding in Guernsey??
Andy
Tax Haven Guernsey
No rust on my 1997/98 Steffi March Cab and only a little bit on the rear drivers side wheel arch on my 2002 SE+ Rouge 5!No rust on mine Super, nor on my last one.both after 2000 so they may have cracked it by then.
Can image the rust is like a biscuit mines a 93 and took so much to take it all out new sills and floorOurs is a '95 car so is now 20 years old, so rust is not that surprising at that age, and the shell has done a LOT of work and all that work does help the rust due to the flexing of the shell with the stresses and strains that events puts on the shell.
Blog is now updated : www.mattendean.co.uk
I mean handing would be Diffrent and will be super quick, what about declaring things with dvla ?Like a micra but faster
You need a headed letter from Nissan or a reputable local garage to confirm the new engine size in cc and the new engine number. I got my letter from Nissan just to be sure. Then you need to fill in the correct section on your V5 and send it off.[/QUOTE]I mean handing would be Diffrent and will be super quick, what about declaring things with dvla ?
That's ok thanks for that infoAnyone who is suitably qualified in automotive mechanics can sign the paperwork
