GA16's rare over there? GA15's seem to be really rare, are they quite common in the Dominican Republic?
No need. There's one running 22psi dailyPerfect for a good bore then.
Time will tell andy running 130ish hp atm !
That should make for an interesting readTime will tell andy running 130ish hp atm !
Aye, we,ve hit the sweetspot in terms of valve timing, spark timing and compression ratio now dinkyLove it . Leading the way for the rest of us frank
Yes filed dowels dinky, been running them for about 8 yrs now, and i believe your motronic can be simply chipped. Mate
you only need a 3mm flat dinky, (for unlimited adjustment, ie, you can turn the dowel and use the next tooth)Got pics of the doweling mate? Wanna try myself. Yea they can be, just dont like the idea of payin for remaps each time I mod something. Rather make a one time invest in something I can adjust myself + learn in the process. Just not sure what yet.
1 tooth is about 20 deg iirc, and you can advance about 10 deg by filing 3mm off, or else advance it 1 full tooth and then retard it insteadSorry pal, can you explain a little more, didnt quite get the turn n use next tooth bit mate
there you go then a 2.5mm flat will suffice1 tooth equates to ~31deg. A 3mm offset on the cam equates to ~20deg
Drove mine back from Bradford, it's particularly wobbly in 4th/5th at around an indicated 30ish, sound about right for a 1.0? It's been like this since I got it nearly a year ago, not enough power I'm guessing?
Really thinking of getting an Auto on my next Micra, I imagine it'd be a great laugh to drive.
30mph in 5th? :O
Sent from my RM-892_eu_euro1_205 using Tapatalk
Not lumpy, just a bit of a wobble. I think I used to knock into 4th around 30 for town cruising. 3rd's the perfect gear for accelerating around town and maintaining speed in 4th.
bought an si prim on monday manYeahhhhh boyyyyy
