1.4what model do you have? that rocker is fairly noticeably different...
LATEST MODEL 2002 Coilpack Engine
if you connect the battery to it, and use a 5w bulb to draw current into the field coils, then it should pump out 14v chrisBugger...
well sit on my face and call me terry
When u going to buy me a Jenson interceptor ? X
...well?....
when I can afford to chuck money at someone to sort out my paintwork...I'l think about it LOL
Yayyyyy....well?....
As Most of you know some idiot drove into my open door...So i made it slightly unique over the weekend....
Ohh and 'slightly' lowered it!!
It's a shame standard tipex (other correction fluids are available) is actually Whiter than the Nissan Arctic white 326 after 7 years on the road LOL ^_^Jen you've got it easy, your car is white! When you get a scratch just whack out the tipex!
you need to raise that g/box like mine jay, for less acute driveshaft angles, (as a result of lowering)Looked at cv boot today. Noticed spray of grease on bulkhead. So it's split again. Best get a correct one and not a stretchy boot. Lol
I rang up motor parts. Lower arm £29 not bad...
Complete n/s Driveshaft £77.51
So just gonna strip Driveshaft and regrease hope for the best.
how would I go about doing that frankyou need to raise that g/box like mine jay, for less acute driveshaft angles, (as a result of lowering)![]()
the mount was piecut and welded on the (lower) red car jayhow would I go about doing that frank![]()
it straightens it joeDoesnt that twist the engine up too? did you have to modify other mounts?
it straightens it joethe engine leans down to the nearside normally
your cams may need dialing in joe, when i did this white car years ago the only gain was @ very high revs, and when i advanced the cams it pulled a lot better low downAll i did today was drive to work and wonder if the 1.3 cams really made much difference?
WDID ? slid by ball up my shaft ! you have to heat the plastic ball a bit to soften it, then shoveghetto quickshift ftw
http://micra.com.au/community/message.php?messageid=81980
most likely about half a tooth joe, the chains tend to stretch such that you can usually turn the crank about 4+ notches on the pulley (20+ deg) while holding a cam from turning, which means that the cams are retarded by the slack in the chains eh.So i could shift the cams 1 link to change timing? Forgive ignorance but which direction would advance? (i keep confusing myself working it out)
yes clockwise mateRight, that'll be another long day in the garageand moving them so that (rotating clockwise) they open sooner than before would be advancing for more lower down power?
Thing is much as i love ragging it i do a LOT of motorways/cruising so really having mid range grunt (or at least an attempt) will make my drive easier and make cruising at 70 less of an effort (hills just drag me back unless i drop to 3rd) so i can just dip a bit more throttle and have power on demand in 5th
yes clockwise matemost members could probably get more gains from optimising the cam settings than any backbox or "spark enhancements"
those 2 events will gauge your overlap @ tdc joe, the 1.0 cams are listed duration 196 deg, 16 deg of inlet lag near btc, and 16 deg of exhaust lead near btc, and zero overlap @ tdc (16/0/0/16)I guess using the events to check the closing/opening positions relative to tdc is most accurate for figuring the advance/retard? opening sooner/closing sooner being advanced?
and 1.3 cams are listed 222 duration (42/0/0/42) no theoretical overlap again, but i find that the 1.3 cams usually have some overlap (where all 4 valves are slightly open @ tdc) i usually set them about 15 deg either side of tdc (30 deg of overlap)![]()
hehIs that inlet opening just before tdc and exhaust closing just after?
Sorry if thats exactly wrong i think i'll need a good read up on this when im more awake lol, not good at 6am start and work at 7, my head thinks its past midnight!
as long as you always turn the engine clockwise, the slack wont factor eh joe, and i just remove the double cap bearing and sprocket, then you can drift the dowel out np (with a cloth to catch it in)(22mm socket, 22mm open end, and a 10mm socket eh)
if you mean that linked pic joe ? the inlet is advanced about half a tooth, and the exhaust advanced a tad (tho its a piper cam), you will probably need to advance them both to correct the chain stretch eh.Just thought with your set up, is that inlet advanced and exhaust retarded? Dont they give opposing effects?
You will probably have to cut yer spare wheel well out n put a flat boot in to accommodate a box that runs across the back of the car..Been given a whole EK civic exhaust system and side angled back box! Will it fit with some mods?
I'll get some pics up later![]()
I fit GreenStuff pads to my K11, great buy.Just ordered some EBC Green Stuff pads for it. The stock Nissan pads are ridiculous, I practically have to remove the brake dust from the alloys with a spade and I'm seeing yellow staining in the lacquer from the Nissan pad dust at barely 20,000 miles. Fitting them in the snow this weekend should be fun though eh
That would be pretty coolNeeds to be sequential :L
