Spot ok mate, I seen a green one which I didn't think about using it ? Will I need that on ?O ring on the idle control valve maybe ?
Sent from my iPhone using T
i thought they were black ? and yes you definitely need it fittedSpot ok mate, I seen a green one which I didn't think about using it ? Will I need that on ?
Mines green am sure I'll take pics Tommow, yes I will put it bk on defo thanks for spitting that onei thought they were black ? and yes you definitely need it fitted
Frank your right they are black maybe it was that much crap on iti thought they were black ? and yes you definitely need it fitted
No I bought the tb from scrappys never knew the condition till todayHave you been driving around in a river? i don't think you're supposed to have sand in your engine some how
Yes got oil from halfords today knowing it's gone all in engine and new filter gona do it TommowYou have spun that dirt all round the system .You might need to clean it out
Too much oil ? My engine is fully build and was running mint on n/a when I started this turbo kit, I have found 2 problems which am sure I can only try Tommow and it should sort itRight now, I am thinking something. You might need to remove this turbo kit so you need to sort out with your n/a engine. You got problems with n/a engine before you should sort out first before you put turbo kit in.
I don't know what to say man. You topped too much oil so it can be damage to whole engine. There are air leaks so your throttle body looks so bad. Sounds like you are killing this engine.
Have you met any experienced members in your area before, if yes then ask them to help you out.
The throttle body u see is nothing like it now, that was a pic I got off the car cleaning and fitting is a Diffrent story and comments will be showed TommowDon't change your oil yet. He was talking about your throttle body. You need to clean this throttle body with carb cleaner. Make sure these solder joints are ok.
I have listen to the tubes I found the fault and fixed no other leaks has found with tube after that therefore no other leaks, I don't have a plate I have a gasket ?Frank said you should listen to these tubes. Don't give up so find these problems.
You know throttle body? Most Micras got tb plates. :s
done final checks today and I have gearbox leak can't find where but the driver drive shafts a bit worned and lose so it can be that, also plugged the sparks out it was so black was this causing the problem ?
Yeh it's running very rich I think that was cause I started it up without my base map and it was over fueling but now have put new ones in and base map should cure the problem, although it's misfiringLet me get my Afr gauge drum out again...
Black sooty plugs are from running to rich
Even with helping me am just on money problems as I have 3 cars I run and will sell this Micra thanks for everyone's helpYou need a good old kick under your ass to bad I am to far away.
Someone please do the honors
It starts and drives but misfires if meaning I'll have to break it up I will I know I shouldn't thoWell selling a working turbo micra will get you a lot more interest and money than selling a project car + it wil give you the satisfaction that you got it done. But it is your choice mate
Sorry I ain't gona do nothing to it any longer it's going on saleFuel regulation needs looking at .aint a big thing.
Am sure my seals was gone from before as bought car very cheap, and oil on seals leaves proveYeh them ones.got to be nice and easy with them.
see my engine mounts were loose. i reckon that extra dodgy movement shook my drive seals leaving gapment
That's the idle cos it's running rich no way I can drive to eds, 180miles, so I will go n/a drive to eds then swap my turbo over and nistune then final remap with ed good plan ehThought you were getting it mapped?
Probably the best option eh AzzyThat's the idle cos it's running rich no way I can drive to eds, 180miles, so I will go n/a drive to eds then swap my turbo over and nistune then final remap with ed good plan eh
Yh that's my best option takes 2 hours to fit and take off so it's simpleProbably the best option eh Azzy
Yes I have a nistune fitted it is running very rich meaning I can drive to eds will cost me 200 pounds in petrol also getting pulled by the police, going up in n/a will cost me 80 pounds in total, plus comin back with no issues, I don't trust no other nistune mappers only edI though you already had nistune fitted it just needs mapped? if that's the case just take it to somewhere near by capable of mapping nistune?
IF you for some reason HAVE to use ED get it mapped someone near by then drive it to his for a final map?
no, just remove the old one and shove it in mate
sounds easy then mateno, just remove the old one and shove it in mate
I understand the nistune can be altered by other mappers I have one local only 2 miles away they do everything from mapping to car builds but I don't wana go back I learnt my last lesson for me it's getting to expensive with trying Diffrent routes to only get it fine tuned I'll be happy if I can just get to eds and have it done 1 timeYou do know that any one who is competent with other systems will be able to use nistune (its nothing special) ?
5 times wouldn't count I had few other problems on my car from oil burns to diff seals gone, now am going the option I think it will most suit just going n/a and fit my turbo at eds and after few hours I'll be drivin home safely, I hope nothing esle happends on my car as there is always a problem,Iv tried saying this about 5 times now jonez
