so @h701micra @pollyp, fancy giving me a crash course in corner weighting... just to remind you that I never, ever, ever, said that corner weighting is a lie...jus saying
Weigh it, if one corner has less weight, raise the other corner.
Sorted.
No... just noWeigh it, if one corner has less weight, raise the other corner.
Sorted.
Defo have a look later dude. You know of any good resources to have a read of?
I know of literally hundreds. Just name a topicDefo have a look later dude. You know of any good resources to have a read of?
lol @pollyp all I can think whilst watching this video is... jesus this man is crazy... he is working in a shirt![]()
curious... I think I can do this. Polly its a shame you aint got anyone to give you a hand. means you could get ur arse in it whilst some one adjusts on your order.
Cleveer move batman. I will need to look in to scales at some pointI had some ballast sand to put in the drivers seat one time but a limiting factor of my balancing rig is that the 300kg digital scales almost max out at the front end without driver weight and adding my weight will overshoot it. so it ain't a perfect rig but will do for balancing up the cars dry weight DIY on my budget.
I forget sometime and start working on the car is my work clothes... Bad move lol. Overalls are they forward. I have learnt to work smart.. Saves on washing up. The bonus is with using gloves and what not, I don't get my industrial Dermatitis flaring up.
Just to be An arse .. No.. Jks courseSo when I tell someone how important and complicated suspension is I can count on your backing![]()
Go up a rate PaulWhat's setting are you running the front dampers at Chris?
Iv the same rate front springs but find there's still too much roll
Alot of it these days is bought for the "I've got this" factorcomplicated n important indeed.
The whole point of a fully adjustable coilover is to allow ppl to tweak & tune it perfectly to one's unique vehicle setup to get the best compromise out of em.
ignoring the importance of tuning them could lead to ending up with the worse compromises of the setup (like running hard slick cold racing tyres on an icy rally stage n say that'll do)
if ppl don't have the patience, resources, knowledge or motivation for setting up suspension, best to get a ready made pre-set one thats roughly configured for their car by specialists.
6 at back and around 18 up front. This was recommended to me. This ratio is good dry and wet. Just remove the rear arb and let dangle when wetWhat's setting are you running the front dampers at Chris?
I considered this, but I think my demands are similar to paul atm and this was my reasoning, tell me if i am wrong. we run on undesirable road conditions and the softer spring allows the weigh transfer. perfect for wet and **** conditions. going harder risks loosing that. I would think upping to a stiffer rate would be more suited to track?Go up a rate Paul
6kg/mm or 280lb/in is my recommendations for you![]()
yeah I get a bit like that with overalls, chokes u when you bend down. oversized overalls ftw! yeah i miss working with no gloves, nothing better, but i cannot anymore.if I'm gonna be welding or grinding or know I'll get mucky then yeah I'll put on my blue overalls (and if it's a nice day and not gonna get dirty then I'll wear me nice special clean rolls royce overall that enuo gave me at JAE)
but most the time I just get on with it in my normal clothes for convenience. also I find overalls quite constrictive when say crouching down beside a hub or bending over.
I try to wear vinyls gloves when I can but tends to rip up and end up washing anyway. washing powder ftw.
there's something nice bout working on engine bits or gearbox bits with baby oily fingers![]()
you not worried about the lack of grip when losing the roll? Biggest sin in my head is not getting that weight to the corners. espcially as you are road racing n all that.What's setting are you running the front dampers at Chris?
See. I need this stuff. Never would have thought of that! I need to get reading. Ta for the input.Weight transfer is good, but it's not the best way of generating grip.
When a car has body roll on a right turn the front right tyre might lose 30kg of weight but the front left tyre will only gain 25kg (just approximate numbers) so your overall grip levels are reduced![]()
Atleast that's what I said in my coursework, probably gonna fail haha
For road use its a tad stiff and it will bobble about. But as a whole still quite a soft spring.I considered this, but I think my demands are similar to paul atm and this was my reasoning, tell me if i am wrong. we run on undesirable road conditions and the softer spring allows the weigh transfer. perfect for wet and #### conditions. going harder risks loosing that. I would think upping to a stiffer rate would be more suited to track?
You're confusing weight transfer and load transferyou not worried about the lack of grip when losing the roll? Biggest sin in my head is not getting that weight to the corners. espcially as you are road racing n all that.
A stiff chassis, shorter shocks and an uprated ARB will do thatThat's the problem Chris the rear constantly cocks a wheel.
Weight transfers a bit much left to right etc but moving to a 280 as Andys suggested might be best.
Your right about the roads we are using, I'm lucky that the hillclimbs on the TT Course so it's race track smooth for that
A stiff chassis, shorter shocks and an uprated ARB will do that![]()
