You driving.... Enough said![]()
+1
Seriously, no idea, as per, but good luck with it any way
yeah cause you only need r888 to achieve that...pfffWhich one of you is rocking R888's?
i bet joe was ehWhich one of you is rocking R888's?
Wasn't taking the piss mate, if you look closely in the back ground you'll see an R888yeah cause you only need r888 to achieve that...pfff
Let me never hear you say that again lol, its never the lsdi bet joe was ehpic from his blog http://www.almeraownersclub.com/threads/my-n15-5-door-gti-build.26850/page-72 they probably hooked up in 3rd gear with the help of the helical diff, and something had to give !
so i blame your lsd chris![]()
Ah that's Joe's almera. Thought it was either of yours or Chris' gearboxes in pieces.i bet joe was ehpic from his blog http://www.almeraownersclub.com/threads/my-n15-5-door-gti-build.26850/page-72 they probably hooked up in 3rd gear with the help of the helical diff, and something had to give !
yeah I know and I was taking the piss... everything I say is set to wind people up dudeWasn't taking the piss mate, if you look closely in the back ground you'll see an R888
No, broken shaft seal, human fault.elementaryits only a guess tbh, was the casing wear the source of the original leak ?
that noisy g/box i changed the other week was stripped last week for diagnosis eh, and the bearings showed confusingly very little wearGot a 30k box to put the diff in. Debating get a full bearing rebuild on it. Or checking the tolerance at least.
Which is why it's so bloody expensivei tried to remove my bearings chris (just tinkering really) and i gave up in the end and f'@@ked it all in the skipg/box building tends to be specialised, with the need for special pullers and stuff
I will learnWhich is why it's so bloody expensive![]()
Please doI will learn
