When my k10 gearbox failed it kept popping out of second and now my other k10 gearbox is doing it. So I dont know what symptoms you got.So yeah. Whoever said cg13 gearboxes are okay to like 200... Err I think my second gear is on the way to blowing up.
A few hundred? Try 1000HzBack to logging![]()
Andy, a large consideration is the required frequency of logging. I assume the pots will be wheel displacement? Will need a high frequency logger IMO. A few hundred Hz
I think tired sync or just bloody warm from the load I was putting on it that day. seems to be okay now! Dude bring ur alignment tommorow?When my k10 gearbox failed it kept popping out of second and now my other k10 gearbox is doing it. So I dont know what symptoms you got.
Welllllll
Waste manso cool,,, you must be fasting too.thanking the creator for all he has given you,,,,,or you a waste man?
Lol quite the opposite... Plus the neighbours down the road were having a rave till like midnight birthday party.... We listened to their music.. Excellent dj... So we got away with a bit of noiseYour neighbours must hate you![]()
Two fords to be exact lolHold on, someone leaving fords on your driveway?![]()
I had to buy some to make use of space, assuming they were the push type I ordered, turns out they blew the other way so were blowing out incoming air. So I ran hot whilst driving along.
They are usually reversible fins to either aid push or pull. Then you change wiring accordingly.I had to buy some to make use of space, assuming they were the push type I ordered, turns out they blew the other way so were blowing out incoming air. So I ran hot whilst driving along.
Granted they shouldn't be running whilst travelling but it was a "I'll do it later" job
Paul (@pollyp) spotted it while he was here last week
No ****. Lol.the blades are curved to run optimally one way to scoop air through the rad. reversing the spin will make it run abit inefficient.
HIGH power is not cost effective on any engine really chris, which is why i restrict mine to 130hpLol so. The fate of the car is decided. I think handling mods are next and power is remaining the same. I am going to go pulsar and can't be arsed messing with pants engines. Will just enjoy the car and get tracking the rude boy. Mess about with interior and play with electronics. Power is not a cost effective pathway to take with the cg13
I suppose, but the reality is sr20 and getting cheaper HP per £ is simply far better than the CG line. Looking at it on reliability. I can forge a sr20 for a fraction of the price. Run less boost. Get more power and put it down better than a micra. I will still keep this car mind. This is my baby! I just don't plan on anymore power for like you said limiting it means we get more horse power hours Lol. Its a fun car I love my micra's. But I am limited by it. I want more power. I want a bigger micra basically.HIGH power is not cost effective on any engine really chris, which is why i restrict mine to 130hp
the factory design a 2 x hp safety margin to the stock engines, and they are pretty bulletproof below that (an output that is very simple to achieve)
How do you run your cooling? Do you know the oil temps?
of all your clever scientific stuff and you dont do oil temp! Is it not much to worry about then?26mm Automatic k11 rad handles heat on track no prob. Stock rad fan shroud was trimmed thinner and remounted closer to the core to clear the turbo inlet nearby.
Dunno oil temp.
tbh if I didnt buy the car with most stuff on... cause I cheated.. noddie built the car lol.. I would run nearly stock everything with a turbo strapped on and uprated clutch and suspension... done. but anyway, the cars taught me a lot and so has everyone here, including yourself. I suppose i could do an sr20 swap, but then I just think stuff it get a pulsar.. and that all wheel driving thing!go for that pulsar chris
tuning an SR is cheaper sure, but i still have the same performance as a stock 2.0 k11, most members go overboard on the CG+t projects and they end up being a moneypit (for the same cost as a tidy pulsar !)
you just dont need uprated fuelpumps/mafs/headgaskets/headbolts/intercoolers/sparkplugs/wideband/clutch etc for 130hp
go for it matelol I will get flak for defecting...right so too, but its just makes sense in my head. I wont be leaving and the micra will still be worked on just power will remain the same.
That would be very cool... Then super charged?Get the pulsar definately. I'm considering packing this all in now, just moving to the next one... I like the idea of getting a classic car and fitting cg/ga ecu/injectors/maf etc to it for easy fuel injection conversion... then having fun with it... So much more room for improvement... so more diy modding fun!
Probably. Off the shelf kits for most popular classics.That would be very cool... Then super charged?
