SirChris
Educated Bodger
Just a little bit lol.. It capable of 700 probs more.. But legality and all that.
Nearly.You got that towbar fitted yet![]()
How do I tag ur usernameI shall hereby be known as Capt Pretty Slow![]()
Ta dude there is a slight change in wire colour here and there as the looms been repaired. There seems to be the req of two rear side lights .. Obvs two power supply less strain on wires. Uses the whole of the 6 core that way. I was thinking there may be a need for them both of them to be live to work. But that would make 24v no? So I rekon trailer is dodgy.i posted my wire colours here chrishttp://www.micra.org.uk/threads/what-did-you-do-to-your-micra-today.43944/page-309#post-660891
"Got any scrap metal?" springs to mind when I see this...
I don't know tbhWhats that black thing on there? Lol
Just like having a look... Immediately regretted it so it came offY rear bumper?
Pots? Hmm you might be able to but my electrical knowledge is still basic. You can input ranges between 0 and 5v so whatever you got in there coolI think Andy is thinking of reading pots, so needs to measure 4 variable resistances?
Oh I know what one of them is. Three leg'd swivel do dadsPots = potentiometer (a type of variable resistor)
Simple potentiometer readings but many of and the signal converted to a value i.e distanceYou log as many as you want depending on a few factors mainly... Processing speed, bandwidth of com lime and latency or speed of you will of read write speeds. What do you want to do
Lol yeah so that's what I said but like betterYou'd supply a 5v feed to the pot, and get a varying 5-0v output dependant on resistance. You'd then need to calibrate it by manually measuring the displacemnt, measuring the voltage and plotting a graph. If you use linear scale pots it should be a straight line, and you can simply work out the ratio of volts-distance. Log scale pots are more complicated...
YepArduino should be capable.
Not doing that againNeed a respray![]()
