Ta mateI think I will need it as ever
People do we think the military look has been over done?
Lol. U da man guy. Love ya dude.Stick with it you great lettuce, it's gonna be awesome.
See you don't get that service with anyone else.. Ta dudepackage status
currently at great barr post office, awaiting collection![]()
Lol read that out of context that time... Kinky basstardIf you need a hand stripping, just shout
In some ways yeah. But how many done well?Personally I think it's overdone, but go with what you want
What are they mate?Have you got flappy grinder discs too?
Will be grinding down and painted. Will consider getting something made up to adjust camber.
Rear disk conversion and 100nx callipers with vented disks.
Adjustable camber on the rear is pretty dam hard to achieve (without making lots of parts). Frank did achieve fixed negative camber by cutting and welding at the back of the hub.
Ed
I remember someone on here did a wedge shape bolted in the middle of the axle. (not sure if it passed an MOT though).Yes, but it can be done! I was a very clever plate system on the ray gimbert tuned 1.3 250 bhp monster. Clever but very simple when you think about it. Cut it and had two plates which pivoted at the top. Used bolts for creating the distance at the bottom end and another set to fix. Seen something like that? If it is silly work I will cut and weld.
Do you have a link to the method above? would be interested to see it![]()
No, I dont, I am
Yes I remember the wedge in the center of the axle. The bloke dropped a cg13de in a k10. Also Drifted.I remember someone on here did a wedge shape bolted in the middle of the axle. (not sure if it passed an MOT though).
This method had adjustment plates either end of the axle, after the suspension recesses and before the drum/disk. /|---------|\
so am I mate, need to do some research me thinks...looking forward to see this custom axle![]()
I dunno mate tbh which way to go. Would like to find some way for adjustable camber and get it made up by a pro. Reminds me I need to get my suspenssion sent off for repair.machisan ?
anyway do the mod on the drum axle![]()
Yeah I think its the only ones you can getwhich discs n pads are going in the back ? i heard (hurd) standard are good enough
Dafuqits got to be said
TALKING OUT MY ARSEIs it possible to do what some of the dub guys do and sit washers between the axle end and the hub(something like that anyway)? big job to adjust it but saves cutting and welding etc...
nah, the hub shaft is welded into the axle, adding washers will just tilt the backplate (brake-rub, and zero camber change)Is it possible to do what some of the dub guys do and sit washers between the axle end and the hub(something like that anyway)? big job to adjust it but saves cutting and welding etc...
Whhhaaaattttttt, I thought the... oh wait. I am talking out my arse. brain lapse.nah, the hub shaft is welded into the axle, adding washers will just tilt the backplate (brake-rub, and zero camber change)![]()
What is it I have worked on where you can do that? was it a golf? actually it was something rear wheel drive and the hub was attached to a plate..nah, the hub shaft is welded into the axle, adding washers will just tilt the backplate (brake-rub, and zero camber change)![]()
dunni bother me lol, me and noddie were both shocked by the massive lump in the cab, he didnt even know it was there. the carpet hides it very well, I took up the carpet without knowing and boob. cracks and everything. Now she is up I can see how bad it is. I rekon sump lump hammer work will helpevery used car has a hidden past and now u found hers eh
Been reading up your threads material on the rear disk conversion. Worried mine shall be seized, we shall find out eh!every used car has a hidden past and now u found hers eh
