+1 pick a turbo that boosts from 2k, and fuel injection and 3D sparkmap (and enjoy )I'd opt for none of the above, all way too complicated and destined for failure and/or dissapointment.
Why not run just the supercharger, you can set them to give you say (for example) 6 psi from idle all the way to the red line...
Well I doI don't see it as breaking the mould
On a GA... will be awesome noBoost from 3k blah blah blah, I want big dirty torque from 1800 revs
Bit of extra weight over front axle will just help with tractionOn a GA... will be awesome no
You'll need it tooBit of extra weight over front axle will just help with traction
that,ll be a turbo diesel thenBoost from 3k blah blah blah, I want big dirty torque from 1800 revs
This Golf is rubbish for that. Turbo takes an age to spool. I want this:that,ll be a turbo diesel then
I'm aiming for september. Realistic, if a bit underwhelming.Finger out then
I look forward to itI'm aiming for september. Realistic, if a bit underwhelming.
Pah, that's the kind of thinking that's put this country where it is now. *cue national anthem and superimposed waving flag* lol.
I'd also consider it pretty straight forward. Though the bypass on mine was purely to help off boost breathing.
Here's the lancia way
They are?this is awesome until you look closer and realise that they're pressurising the fuel as well....
How else do you move fuel? You try and get fuel at 0psi to move into a chamber thats at 6+psi...this is awesome until you look closer and realise that they're pressurising the fuel as well..... no wonder there were fires in group B!
I forgot these were carb'dHow else do you move fuel? You try and get fuel at 0psi to move into a chamber thats at 6+psi...
I didn't know, If they are carbed Tom could be referring to it being a draw tgrough rather than a blow through design. With fuel injection its a non issue...I forgot these were carb'd
Noob fail
Was MPi around in GpB days? :/I didn't know, If they are carbed Tom could be referring to it being a draw tgrough rather than a blow through design. With fuel injection its a non issue...
MPI? to me thats Meuller Phipps InjectionWas MPi around in GpB days? :/
Multi Point InjectionMPI? to me thats Meuller Phipps Injection
Was definately about, would have thought regs would have determined it...Multi Point Injection
Seems reasonable... but it'll be a question of space again?What about twin-charging with a screw supercharger and a centrifugal supercharger, with electronic clutches switching between the two at the moment the centrifugal charger overtakes the screws ability to create boost?
I understood none of that to be honest
Makes more sense.Sorry for that...
Like this but with the throttle body before the supercharger:
Final boost:
[(Turbo Boost + 1bar) * (Supercharger Boost + 1bar)] - 1bar = Final Boost
Aye I get all that(1bar + 1) * (0,5bar + 1) - 1 =
2bar * 1,5bar - 1 =
3bar - 1 = 2bar
Seems good for me using bars.
But even if you only see 1bar on the turbo outlet, you need it to flow like 2bar as all the air must flow through it.
Aye I get all that
It was 500+ psi figure
Bar is much better, imperial units are a relic from when britain thought it ruled the world...(1bar + 1) * (0,5bar + 1) - 1 =
2bar * 1,5bar - 1 =
3bar - 1 = 2bar
That's exactly why I think its a brilliant idea and can't understand why people haven't tried?At 500+ psi it would get some proper HP figures
Oh, and i forgot one thing, because of the compound charging, the intake and exhaust have low pressure differencial, you can use some wild cams like on a NA engine.
they run about half that at the tractor pulling 3 or 4 turbo,s running in seriesAt 500+ psi it would get some proper HP figures
