From what I've read, when the throttle is closed, because the carb is before the turbo, the turbo is just pulling against a closed throttle plate so pressure will drop by itself. Or something like that, it's been a whileJust another point ive thought of... what about pressure dumping? You don't want it dumping through the carb
Can't run a dump valve on a drawthrough, it's not just dumping compressed air, it would dump air/fuel. Wouldn't want that dumping in a hot engine bay!The dump valve is a much simpler approach imo
So as you drive past a bus stop full of pensioners and come off the throttle you dump unburnt fuel over them? And one of them is smoking a fag lolFrank said if the dumpvalve was ventilated outside of engine bay ? That or a component of a diesel , have to look at that again
And the throttle body purpose was to prevent oil Problems
Thanks for that but I dont know everything and I'm not infallible. Just like everyone else I'm trying to learn stuffwhy do i question anything you say on this topic lol
But hopefully by that time most of the energy is used by the combustion process, it's not pure compressed air/fuel!Unburnt fuel mixture is always coming out of the exhausts of old carb cars
But surely that's better because it will slow the turbo, not stall itYea it does make sense but a throttle plate never fully closes. So your always drawing an air fuel mix
Turbos wont stall as exhaust gas is always passing over them. I'd rather dump or recirc pressure rather than strain the carb or other partsBut surely that's better because it will slow the turbo, not stall it
Nope that's very true but when dumped its no longer compressed. Going from turbo temp to atmospheric temp that fast condenses the fuel. So burning it off is the safest in dump valves applicationsBut hopefully by that time most of the energy is used by the combustion process, it's not pure compressed air/fuel!
Isn't everyone. You've popped a few things up so far that stumbled me a bitHey, I'm here to learn too
Just re read it properly. The dump valve would go post turbo and pre inletEDIT : just read your other post , so ill need to build a flange where the carb meets turbo that a dump valve can be placed on
Yea same place and recircs back to pre carb iircsorry, feeling a little stupid here well would it be the exact place that a diesel recirc valve would be fitted? just sussing up the options between this and a dump valve, although dumping the mix, would that not result in a larger fuel consumption than this setup will already use?
Dump valve is for those who don't care much for fuel economy
Thats fair enough. Any pressure relief valves operate when throttle is closed. If they did while open you'd never get boost as it would constantly be vented.and correct me if im wrong, but isnt this the times when the bov recirc valve operates ? when the throttle is closed? so if i fit one i just gotta pipe it back to intake?
sorry about all this, id really love to know everything about this before i set it up
H701 says to stay away from diesel turbos so looking for one off a petrolt15 from 1.3 cdti astra/ combo?
mine tooMines off a diesel lol
I think mine might be a t15mine too
Only because you dont get tge exhaust housing separately these days. The mani is part and parcel. Petrol will be easier as its a sole unit but there's no reason you can't use oneH701 says to stay away from diesel turbos so looking for one off a petrol
mine,s a gt1549 (mera/audi/vw/rover/transit etc) 2.0 D, bulletproof little jobbies nowadays, that,ll run for 100k miles no sweatI think mine might be a t15
how do i find out exactly which it is?mine,s a gt1549 (mera/audi/vw/rover/transit etc) 2.0 D, bulletproof little jobbies nowadays, that,ll run for 100k miles no sweat
what numbers are etched on adam ?how do i find out exactly which it is?
