True but it is under extreme vac?
But is it? The turbo in a drawthrough doesnt 'drag' the mixture through the carb does it?
how would i know if pooling occurs?
It can do. They work under atmospheric pressure fuel push. A turbo gives you vacuum pull.But is it? The turbo in a drawthrough doesnt 'drag' the mixture through the carb does it?
As you climb rpm on na the 'scavenge' effect draws air in at a constant increasing rate iirc
Boosted engines draw air at a higher rate as boost increases. Creating a vacuum pull
You'll have to inspect the turbo compressorhow would i know if pooling occurs?
Mine too man mine too. I dont do explaining thingsOk, that makes sense to me, though my head is starting to hurt...
Not too big I'll find one you can use as referencedont be sorry its great to have somebody to tell me all this ! swirl tank it is with this idea it doesnt seem like too much work , how big should it be? ( no immature responces please lol )
Wouldn't worry about mechanics.. no cars anymore just computers... I love my old cars
Your more knowledgeable than you think ade
Old cars ruleI miss the simplicity of the K10. Everyone thinks I'm crazy cos I get excited at old cars and think most new cars are meh!
Ade from what i see you know a lot , plus , im 18 and i see no attraction to all my friends golfs , bmws and civics , no ECU all the way
The small nipple should be at the bottom.
The bottom pipe is in
The top pipe is out
Bottom should be a bowl shape. Not too big at the top
When I was first told by an old boy I thought he was having me on. The inside of those things aren't smooth so they cause turbulence which in turn atomises fuel.Sorry but I'm yet to be convinced
With the air not being cooled it'll be a tad warm especially so close to exhaust
Never said you have to just helpsOk, but I'm still not gonna fit a swirl pot when I build mine Cheap and simple.....like me
I think it's purely down to the fact that most cars are fuel injected tbh.Good point ! Just wonder why more dont go for this set up in that case ! Better not think about this too much or might get second thoughts
No i dont believe i was just saying if it can be done with EFI , and came factory standard at one stage , it cant be to badDo you believe for one second with the research I've done in this that I haven't checked out you tube?
Do it... do it now
Have you seen this before ? No ,Just seen the vid, it just begs the question....why?
