Just asked a friend to find a supercharger for my project, he´s working there in UK. Hope do get all the parts needed and make a project similar to yours... (Y)
yeah, but i'm having to scrape for insurance for a bog standard 1.0(problem with being 17) so, this'll have to be left a few years :glare:
solarice, think its time you updated your avatarha ha
Your car is truely awesome in every aspect, muchos respectos to you
damn its clean!! how much respray cost you mate?
cant you have a switch on the throttle that disconnects the lambda feed on anything over 1/4 throttle or whatever kris ?
Yeah frank thats how ive just set it up![]()
gtsnissanb, yup thats why i figured i'd give the stock ecu another look in seeing as it really likes to keep things in around stoich.
Btw fuel map, is blank across cruise now with just the boost sections filled (like you're supposed to with a piggyback)...just seems odd that with lambda running on cruise and then when it looses that feed i.e. hitting the set throttle position...its upping the fueling.
I can only assume the stock ecu is overfueling itself for protection and then the emanage is putting fuel on top. What i dont get is why it doesnt do this when the lambda has been removed from the very start.
All tests carried out with a full reset ecu (battery disconnected for a bit).
The car doesnt feel good while its overfueling (different feeling to how it does it without lambda), not sure if its the extra fuel or if the stock ecu is also fiddling with the ignition...its seriously down on power.![]()
:s very unusual indeed! Maybe it's time to get a standalone? Or nistune don't understand why the piggyback isn't sorting it?
Thats the thing, the piggyback works fine 100% when i dont let the stock ecu get any lambda feed...sorting cruise is more hassle (the main reason im looking to cheat lol) but apart from that.
Can only be the stock ecu meddling. Think my plan may have back fired lol. Nah no standalone going on, will just make the piggy work...even if i have to remove my new wiring.![]()
i have something similar when i switch the 2nd coolant sensor on or off kris (not the fuel enrichment trick i had previously, it just forces the ecu into closed loop when the engine is still cold if you run the 2 sensors together)What i dont get is why it doesnt do this when the lambda has been removed from the very start.
like as if the ecu had booted up with what was there at the start and was sticking with it![]()
this sounds worth a try at least, worst that can happen is it doesn't worksolarice; said:just revert to lambdaless...and map the emanage more like a standalone.
What I don't get is has it always done this? Or just started
Ive been mapping more like a standalone and lambdaless all the time.
But have always wanted to let the stock ecu handle cruise (more likely to save fuel imo)...so ive only just wired it up to give it a try. Just seems like the micra ecu may have more input than i thought (and i know it has alot already lol)
So technically its only just started doing it, but only because ive made it do it. So its a fault/issue of my own doing, i suppose.
Wirecutters at dawn is an increasing possibility.
Bingoit's the ideal afr for optimum combustion
Its been many years since I've seen this mate, and it still blows me away!!
Titch :kungfu:
Not for power... :laugh:
