Added the new badge!
Finally got her in the garage. Starting to put bits back together. Having to bodge quite a few panels as bolts had snapped, and plastic bolt things were almost all broken.
I redesigned the horn wiring as I first made it years ago.
I also changed my mind about the side markers. I've now set it so that the top LED comes on with the sidelights, but the bottom one comes on with the indicators.
Headlights are in. The LEDs in the indicators at the front made it a nuisance.
Got the same air fresheners from years ago, because they match the interior styling so well! Now there are clear ones and blue ones. It's been ages since I had fresheners!
And finally that's one assembled K11.
I went and got fuel, but on the way back, I was down one cylinder. Engine warning light on the dash, as well as tractor sounds. Just like when the coilpack failed.
Not sure right now why it happened, but I'm thinking the injectors I used were crappy.
I was also quite frightened by a load of smoke coming from the engine bay as I stopped, but I think it was steam. The engine was out in the rain all of last night, and the smoke/steam happened when I got to a large gradient.
I also need to investigate the oil leak issue. I don't really know where it's coming from, but I think it's the sump gasket. Or the sump. Or the crank pulley seal.
Sent from my HTC One_M8 using Micra Sports Club mobile app
