This was a couple of days ago. I tested the disassembled T3 in the switch arm for the light aim. Super bright!
The biggest problem was with the wires I had to put through it. There's no space for them in there when the knob turns. This was the best solution I could come up with, using recycled small gauge wire from Cassie.
After lots of fiddling, to get the wires out of the way, it worked. Though, it's still not quite as smooth as before backlighting.
My phone just couldn't get the light right. Here's with the flash on..:
And with the flash off..:
So. I decided to transfer over my air controls box that I had in Cassie, with the custom backlighting.
Unfortunately I've been very stupid in the past with removing the cables that are pushed when you turn the knobs, and have broken all of the fittings. I spent
all day and night raging away in there trying to get these cables to stay in. The temperature one and the fresh air one wouldn't stay. I had to abort mission...
Today:
I have left the car looking like this for a couple of days. The wires going into the glovebox are going to the dimmer switch which was loosely in there.
With no pictures (it looks terrible), I managed to get the two cables to seat in place using a lot of hot glue and patience. I also inverted the C clips that hold them in place so more was holding them. Annoying I've bent a couple of the cables, so for instance the temperature knob, after you turn it to full cold, will turn back to almost where the blue ends. This might un-bend over time.
I was just thinking, "I should label all of these wires, in case I need to open it all up again". And then I found a label with exactly the information I wanted on it! This wire is here for the mirror switch backlight when it goes in. Good job, past me!
Sadly I've not got that many photos after this as I was concentrating too hard on it all. I trimmed down the dimmer switch as I thought it was clashing with the container in the arm rest. Turns out it was just the wires, they had no room.
So I settled for this rather rough looking wiring. Luckily, if the two wires that are really bent do touch, nothing will happen other than the air controls box being super bright.
While I was waiting for the glue to dry on my seatbelt buckle (it's been broken for a while now), I took the relay bracket I had been using to support the arm rest and chopped it in half, and added another hole. So now I have two brackets which shamelessly are cable-tied once again to the arm rest, but now with two of them it's much more stable.
Near the end, I got a notification that one of my favourite YouTubers, ChrisFix, had heart-reacc'd my comment on his latest video. Hell yeah!
All done, both switches in place, backlit, and functional! Sadly, the dimmer switch never did go all the way in, and it barely dims the lights, but it's good enough. The headlight aim is being a little annoying in that it won't quite select option 3 unless I hold it, but that's almost never used anyway.
Edit: Some time has passed and the wires have settled in, it now selects all options with now problems.
To finish off (as I was starting to freeze out there) I rewired one of my horns that had broken due to a faulty wire, and switched to regular T10s in the sidelights as one of the orange painted ones were burning and becoming black.
Still much, much more stuff to do on this new car, but I'm getting there. Slowly.
Sent from my GT-I9505 using
Micra Sports Club mobile app
