Hi, try 7358 or 1358......,
The battery recently went flat on my 2007 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP5384 7 1220171
And nissan MMR CD-C
7645384318
It would be amazing if someone could send me the code for this!
Many thanks
Siamak
Check that there is not a 'BP', followed by 12 digits, number engraved/stamped on the side or back of the radio.......Hi All, i have a 2005 Nissan micra, battery changed and radio needs a code, i have taken the radio out but there is no serial number.
I have model number 55610156706 Nissan MM CD-K(BLK)
part number NS 8 635 123 393 0
please can someone hielp?
cheers
Hi, try 5422 or 1422......Hello to everybody,
I am a new menber of this forum, I have the some problem on the Micra K12 (2003) after I had replaced the old battey with a new one.
Radio details:
BLAUPUNKT – BP234631955935
Nissan MM CD-K 7642346318
Thanks in advance for any help, best regards Stef
Hi, anyone can help with the code, Nissan micra 2007.Hi, try 7358 or 1358......
Hi, try 7790 or 1790......Hi, anyone can help with the code, Nissan micra 2007.
BP5384 7 1210573
Thanks bro, the first one workedHi, try 7790 or 1790......
Hey bro! I have a question, before I start the engine, it shows 198 service on the display, is it normal?Thanks bro, the first one worked
Sorry it’s 199Hey bro! I have a question, before I start the engine, it shows 198 service on the display, is it normal?
It's a countdown to when the next service is due, assuming it was reset after the last one, with the correct mileage interval to the next one.......It's all in the handbook....Sorry it’s 199
Hi,Hi another newcomer to the forum. Changed battery and radio asking for code. 2005 Micra 1.6 RS. BP536556439191. Is anyone able to assist please?
Typo in the 'BP' number that you have posted, there should be 12 numbers after 'BP', not 11.........Hey I have a Nissan Micra Sport SR
Radio is a BLAUPUNKT-WERKE GMBH and the serial number is BP58761149483
could anyone help?
That's better, try 8385 or 0385........Oppps!! Here it is! BP5387 6 1149483
8385 worked! Thank you !That's better, try 8385 or 0385........
Hi,Hi,
I got a message, on my newly bought Micra from 2008, which is asking for a radio code.
Serial number should be DD226F568498
Thank you
HeyHey I have a Nissan Micra C+C
Radio is a BLAUPUNKT and the serial number is BP538875192616
could anyone help?
Hi, your code is 4308Hi,
I have a Nissan Micra K12 SPORT+
Just had some work onto the Alternator... Radio is now asking for code.
Radio is a multi CD BLAUPUNKT and the serial number is BP536556447169
Please, could anyone help?
It works Mega thaniksHi, your code is 4308
Hi, your code isI RECENTLY PERCHASE A NISSAN MICRA AND THEY GAVE ME A CODE FROM AN OTHER CAR. CAN YOU FIND THE RIGHT CODE FOR THIS MODEL radio code BP234631979055.
Hi, your code is 8196Hi, i need your help please
BP334947302682
Hi John I’ve just pulled the radio from my GF 2004 micra and the code is BP334947316931Check that there is not a 'BP', followed by 12 digits, number engraved/stamped on the side or back of the radio.......
