Dont worry Aronld.. its still making progress!! lol
Been crazy busy at the moment.. and to add to it, I Can't find my digi cam..
So its mobile phone picture time..!
Ive had to make a decision regarding the work on the car..
Basically, Ive just got a New Workshop as Arnold Knows and ive had a few issues with getting fully in.. the last Tenent has REMOVED things he should't have done and hes LEFT some crap he sholdn't have done..
Meanwhile ive been putting off the car to a degree as I didn't want to start the big work incase i could get in before xmas and therefore get the job done much much quicker..
But due to not knowing EXACTLY when I can get in now.. Ive just started the major work at home..
Ive brought most of the parts needed for the conversion to my house and have started.. So, the sooner its moving, the sooner I can get it into the unit !
EeeNnnnEeeeWWWAAAYYY!!..
Ive prepped the block for fitting. Which consists of removing A/C - P/S pumps.. and changing Engine side mounts with N15 GTI ones ( Slightly smaller and AS NEW condition ), quick examination and labeling certain things, trimming electrics and some minor stripping..
Ive removed the rest of what needs to be removed for the time being from the engine bay, plastics and wiring.. some will be going back in, most wont..
This gives me as much manouverability as possible for sighting in the shafts and linkages.. etc
Engine Bay Plastics will be going back in and trimmed up to suit nearer the end of the engine work..
Ive sourced an N15 GTI Radiator with dual Electric fans as I think this is Probably as good a fit as Im going to get, makes plumbing 'upfront' easier. also its a Rad made for the SR20
Plan now is to situate the engine in the ideal position..
Allowing Bush movement ( ;p )
Reasonable Access to most of engine once its in
Shaft and CV Joint Cleareance
Neat electrics and plumbing..
Usable Exhaust Route
Ive tried it, in what I think is the ideal place in it fits quite nicely, but ive got to pick up an N15 Underbrace and mount 1st thing before I can situate properly..
( ^^the front of the car is elevated and the engine is actually sat on the floor here ^^ )
Il find out tomorrow morning if im in work or not.. and If im not then It should be mounted and running tomorrow night..
Woo!
Either way its going to be running and drivable by the end of the week..
