frank
if you haven't changed the turbo or computer/tune...standard thickness for sure. you don't need more lag from the turbo
if he,s having the block and/or head skimmed, it,ll raise the C/R tho eh
The turbo is still stock as far as i am aware, it has been remapped my Ed (correct if in am wrong Ed please?) and it has some induction pipework and inter cooler which may make a difference, i will be running boost at 0.9 - 1.0 bar no more
sorry to sounds stupid but whats the C/R Frank?
Im so sad ive drawn up a list to do and pricing
:laugh: been there done that, even had it up on the wall as a check list.
good luck with the rebuild.
ah great so im not going mad then
im kind of looking forward to it but not for two main reasons:
1. all the turbo engine looks a mass of wires / sensors / boost lines etc etc etc which i have no idea how i am going to put back corrrectly
2. I have spent too much recently (surely worth it though )
Could build it in my sleep at this stage
If all else fails you will be sent a ferry ticket in the post
so i take it the super charger is supposed to sound like a dieing cow?
can anyone tell me what each fuse on the fuse box does as i cannot read Japanese and a few have some how blown and dont know what they are?
cheers
hi,
i have a horrible sinking feeling now after looking for play in the turbo spindle, it does move ever so slightly from side to side on both spindle ends, but the blades to not touch the housing. Also i did not notice any smoke when it was running though?
There is no side to side play
so this leads to a few questions:
1. How much would a new turbo / recon of this one be? and who to ask about it
2. on the turbo are you supposed to be able to move the vaccum actuator freely as this one one budge
3. what is the sensor on the turbo with the black wire coming out? (mine goes nowhere)
i take it you used the k11 1.0l rings and filed the ends so they compressed more into the bore? would this fit and work?
one thing i have just thought of, what would stop me from applying this principle with MA10 rings, as i cannot imagine there being much difference?
Steve
When i went in to collect it he said the bores are worn and i think the work card said 6 thou (0.006")? has been taken off the bores and there are still small patches towards the top of the cylinder un-honed, he suggested i might get away with 'new piston rings' now i know i cant get hold of these, i might have to get some made?
Ignore them. I'm telling you now it will be fine. Just get your hands on a set of fig con rods and pistons if you can.
Figs like to think they are special and their car is a one off, it isn't. There are minor changes required for compression etc, but 99% of the parts are the same. Don't forget for every ST made (which truly is a one off) more than Two figs were made. Also the Fig engine was used in the 1985 March Turbo, so there really is nothing special about it, its design is just 4 years older and much less advanced/refined on the ECU/ancillary side of things. BTW nissan did a special 1.0 non turbo race engine on the MA10 block which used ST intake manifolds and tubular exhaust. It made the same power as fig turbo. That gives you partly an idea just how much better the ST stuff is for performance point of view.
ed mentioned the oddball gudgeon pin size steve (re conrods)
if the machine shop mean the bores are 6 thou over stock, then thats not too bad (haynes says 4 thou max, but they,re always very conservative imo)
personally i would just get some custom .25mm oversize top rings made and assemble the engine, and then if there is any piston slap, it,ll be $$$
