It may not be helping!I bet this is the reason why it's not getting enough fuel lol
Sweet, I had a right ball ache trying to fit a tachoAlso, I hooked up rev counter for quick look, it loses power at 4-5 k, tgem feels like its coughing lol.
I've tried going from 1.3 to 1.6 jetts, even bigger maybe?
What jets were you running in your previous k10?I've got 2 sets, one lot drilled to 1.6, another I've done to 2.
I'm running without turbo, for now
Mine wired up easy enough but couldn't get a stable readingTacho wired up easyjus need to make it all neat
And now you're building a quad carb turbo! Yay!No idea, bought them off superls, back when I knew even less than I do now about engines![]()
Won't make any difference unless the bowls are overflowing (but you would see fuel coming out of the overflows), with carbs the fuel is dragged out of the float bowls via the jets.
The floats regulate how much fuel is in the bowls, when full they shut of the supply and as it drops they open up to allow fuel in. The only real difference fuel presure makes is how quick the bowls fill up.
It could be worth cleaning them all.
This diagram might help explain which jet does what
Even more surprisingly....so do I !!Thanks, I surprisingly understand that
Didn't valve clearances come up a while back neil??Jus been goin they some bike forums with same problems as me, valve clearances could be a problem,
I ave been having trouble with ignition, cylinders not firing unless lead was jus hovering above plugs (very strange) got better with overnight charged battery, would a failing battery give a 'weak' spark at WOT?
Didn't valve clearances come up a while back neil??![]()
is yours points ignition neil or electronic ? because dwell can effect the strength of spark eh
May be worthwile, only a tenner for a new one and you have had ignition issuesI've ordered new rotor arm, dizzy cap, maybe should order new coil too
So would a weak spark be causing these issues?
Sorry I lied, just checked my Ebay purchase history and it was £5.99 plus £5.99 deliveryI got one off the bay some time last year, brand new, a tenner delivered, transformed how mine was running![]()
Take your dizzy cap off, take a photo of inside dizzy n put in on hereHmmm, do motor factor places stock these? Or is a order in of eBay affair?
Embarrassing as it sounds, how would I know what ignition type I have? Points or electrical ignition? (Really need a basic mechanics course!)
the electronic dizzy has 2 or 3 wires iirc neil (and the points one 1 wire ?)Hmmm, do motor factor places stock these? Or is a order in of eBay affair?
And 2 wires inside?Mines screwed on.
And 2 wires inside?
